flaps again
Old January 2nd 08, 05:05 AM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
Default flaps again
I've often met pilots who use no flaps on landing in very gusty
conditions or stiff crosswinds. I've tried this and don't really see
the benifits. Like a lot of things it's probably mostly in the head. I
think the higher touchdown speeds invovlved and the resultant float
only prolong the agony.
Do large jets ever land without flaps for any reason? I have never
seen big jets landing without flaps.. so I have often wondered if it
is something not recommended.
Old January 2nd 08, 02:08 PM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
F. Baum
Default flaps again
Large jets never land without flaps. There are backup systems for the
flaps and LEDs in the event of a failure.
FB
Old January 2nd 08, 03:40 PM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
F. Baum
Default flaps again
Not only is this not recommended, it is not allowed for a number of
reasons. First, the clean speed on most airliners is between 220 and
250 KTS, you would never fit into the pattern at these speeds and if
you were to touch down this fast you would use more runway than many
airports have, not to mention melting the fuse plugs trying to get the
thing stopped. Another biggie is that you only get 9 to 11 degrees of
pitch during flare before you get a tailstike. This is extreemly easy
to exeed without flaps. Even with 15 degrees of flap you can bottom
out the thrust reversers on several models of the Boeings.Reduced flap
settings also have a dramatic effect on the Quick Turn Around limits.
The brake tempurature has to be below a certain value before we can
begin a takeoff roll (To assure enough brake energy in the event of an
RTO). Some jets have a brake temp gauge, Boeing uses a graph that
takes into account HW/TW, RWY slope, landing wieght,temp and the flap
setting. The lower the flap setting, the longer you have to wait for
the brakes to cool and this can (And does in the summertime)
ocasoinaly result in a late push.
FB
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
flaps Kobra[_4_] Owning 85 July 16th 07 06:16 PM
Britney's flaps Michael Baldwin, Bruce Products 0 December 9th 06 12:34 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
f-84G Flaps question Frederico Afonso Military Aviation 0 September 8th 04 05:58 PM
