4130 can't be OA welded?
Old January 3rd 08, 04:39 AM posted to rec.aviation.homebuilt
Maxwell
Default 4130 can't be OA welded?
"Blueskies" wrote in message
"clare at snyder.on.ca" wrote in message
It is not your standard brazing. It is "fillet brazing", using a much
stronger "spelter" than your standard braze. The process uses a gas
flux (a "Hookah" bubbling the acetelene (I think - might be the O2)
through the liquid flux ). The flux in the flame is EXTREMELY
reactive, so the flame "scrubs" the joint, leaving little if any flux
behind. These brazed joints ARE stronger than the 4130 or 4140 base
metal.
The process was developed for and used extensively by small race car
chassis fabricators in England and the continent. Lotus is a good case
in point.
What is the melting point for the brazing material?
Depends of coarse on specific alloys, but in rough numbers you can figure on
about 1700 for brass filler rod as compared to 2600 for the steel. So you
have a valid point. The next question is what kind of temps will a oil or
fuel fire generate, if being accellerated by 70 to 100 mph intake air?
4130 sheet log Home Built 4 September 1st 04 01:42 AM
4130 - bad news... Richard Lamb Home Built 28 May 17th 04 04:08 PM
IS the US out of 4130 Steel? mallakka Owning 0 April 21st 04 10:48 AM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 03:04 PM
4130 frame? Steve Thomas Home Built 23 August 27th 03 05:50 PM
