AIP Question
Old January 5th 08, 01:13 PM posted to rec.aviation.ifr
Ross[_2_]
Default AIP Question
Sam Spade wrote:
Ross wrote:
I have a question regarding the rings shown on some charts and not
others. They are a dashed ring and are labeled "FEEDER FACILITIES"
and/or "ENROUTE FACILITIES". The may not be on all charts nor both on
the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF.
I tried the Google route and that didn't work. I thought some of the
ATC folks could help me find out their meaning.
Ross
KSWI
A more complete answer is: where a 10 mile ring is shown, the chart is
not to scale outside that ring. Where a 10 mile ring is not shown, the
chart is to scale throughout the plan view.
Example:
http://www.naco.faa.gov/d-tpp/0801/06941R18.PDF
So a circle will always show either a fix for the feeder facilities and
/ or a VOR, etc for enroute facilities and the circle will go though the
fix or VOR, etc? Just want to be sure I understand.
Old January 5th 08, 07:48 PM posted to rec.aviation.ifr
Ron Natalie
The circle is just for cartographic convenience. All it shows is that
the stuff outside the circle is NOT to scale. The stuff outside the
circle might be feeder stuff or it might be an actual piece of the
approach (an IAF may indeed be outside the circle).
You're reading too much into it.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
