george wrote:
On Jan 7, 1:53 pm, Some Other Guy wrote: So you have hundreds of passenger devices on the network. Due to a bug, one or many may malfunction and cause a packet storm, either bringing down the network or causing unacceptable latency. High latency can cause autopilot oscillation and loss of control. Oops. We are talking about the flight systems of an aircraft with, as I suspect you're aware, two pilots who are there and are trained for such an eventuality. In other words, you think it's okay for an in flight entertainment system to cause the aircraft flight control systems to misbehave. This is where you and I disagree, and I have nothing more to say about that. |
On Jan 9, 12:19 pm, Some Other Guy wrote:
george wrote: We are talking about the flight systems of an aircraft with, as I suspect you're aware, two pilots who are there and are trained for such an eventuality. In other words, you think it's okay for an in flight entertainment system to cause the aircraft flight control systems to misbehave. No but that won't stop you making the claim. If such an unlikely event might occur the pilots will go through their drills. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems This is where you and I disagree, and I have nothing more to say about that. Promises |
On Tue, 8 Jan 2008 16:35:49 -0800 (PST), george
wrote in : If such an unlikely event might occur the pilots will go through their drills. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems In fly-by-wire aircraft there are no truly manual controls, are there? What if the flight crew found their attempts at control input ineffective do that a hypothetical hack? Are the interconnected systems designed to prevent the crew's loss of control to the automated systems? |
Larry Dighera wrote in
: On Tue, 8 Jan 2008 16:35:49 -0800 (PST), george wrote in : If such an unlikely event might occur the pilots will go through their drills. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems In fly-by-wire aircraft there are no truly manual controls, are there? What if the flight crew found their attempts at control input ineffective do that a hypothetical hack? Are the interconnected systems designed to prevent the crew's loss of control to the automated systems? I know. Tirbe |
george writes:
If such an unlikely event might occur the pilots will go through their drills. There aren't any drills that would help. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems They are not trained to handle such problems. When the aircraft is controlled by computer and the computer fails, there isn't any training that will make any difference. |
Mxsmanic wrote in
: george writes: If such an unlikely event might occur the pilots will go through their drills. There aren't any drills that would help. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems They are not trained to handle such problems. When the aircraft is controlled by computer and the computer fails, there isn't any training that will make any difference. Nope, wrong again. Manual reversion is primitive in a 'bus, but adequate for the task. Of course, don;'t take my word for it. I've only been trained to fly one and have. You are an idiot. Bertie |
On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip
wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? |
: On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Go **** yourself killfile boi Bertie |
On Jan 10, 8:16 am, Larry Dighera wrote:
On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Oh lord no. We pray toward the right and the aircraft responds by turning right. It would be blasphemy to have a connection between controls and control surfaces. Cynical mode off |
george wrote in news:df5c7fac-837e-4313-b2b5-a0bc3f04f011
@d70g2000hsb.googlegroups.com: On Jan 10, 8:16 am, Larry Dighera wrote: On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Oh lord no. We pray toward the right and the aircraft responds by turning right. It would be blasphemy to have a connection between controls and control surfaces. The rudder and the stab are both stil physically ( hydraulics) attached to the flight controls. Crews are trained to land the airplane using these alone. It hasn't had to be done for real yet. Bertie |
What are Boeing's plans? | Pooh Bear | General Aviation | 55 | September 30th 04 07:59 PM |
What are Boeing's plans? | David Lednicer | General Aviation | 6 | September 27th 04 09:19 PM |
What are Boeing's plans? | Pooh Bear | Owning | 12 | September 27th 04 09:07 PM |
What are Boeing's plans? | Pooh Bear | Owning | 13 | September 27th 04 06:05 AM |
What are Boeing's plans? | Larry Dighera | Piloting | 0 | September 17th 04 11:57 AM |
