FAA: Boeing's New 787 May Be Vulnerable to Hacker Attack
Old January 9th 08, 07:02 PM posted to rec.aviation.piloting
Mxsmanic
Default Boeing's New 787 May Be Vulnerable to Hacker Attack
george writes:
If such an unlikely event might occur the pilots will go through their
drills.
There aren't any drills that would help.
Computerised systems falling over is not a new thing
That's why the aircrew are there and trained to handle such problems
They are not trained to handle such problems. When the aircraft is controlled
by computer and the computer fails, there isn't any training that will make
any difference.
Old January 9th 08, 07:05 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
george writes:
their drills.
controlled by computer and the computer fails, there isn't any
training that will make any difference.
Nope, wrong again.
Manual reversion is primitive in a 'bus, but adequate for the task.
Of course, don;'t take my word for it. I've only been trained to fly one
and have.
You are an idiot.
Bertie
Old January 9th 08, 07:16 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip
wrote in :
Are you implying that there is a physical link between the flight
controls and the control surfaces?
Old January 9th 08, 07:19 PM posted to rec.aviation.piloting
Larry Dighera wrote in
wrote in :
Go **** yourself killfile boi
Bertie
Old January 9th 08, 07:40 PM posted to rec.aviation.piloting
george
wrote in :
Oh lord no.
We pray toward the right and the aircraft responds by turning right.
It would be blasphemy to have a connection between controls and
control surfaces.
Cynical mode off
Old January 9th 08, 07:43 PM posted to rec.aviation.piloting
george wrote in news:df5c7fac-837e-4313-b2b5-a0bc3f04f011
@d70g2000hsb.googlegroups.com:
wrote in :
Oh lord no.
control surfaces.
The rudder and the stab are both stil physically ( hydraulics) attached to
the flight controls. Crews are trained to land the airplane using these
alone.
It hasn't had to be done for real yet.
Bertie
Old January 9th 08, 08:00 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 9 Jan 2008 19:43:17 +0000 (UTC), Bertie the Bunyip
wrote in :
Unless there are hydraulic cylinders attached to the flight controls
to activate the rudder and elevator (doubtful), there is going to be a
requirement for hydrolytic pressure from a pump to activate those
control surfaces. If that hydraulic pump can be controlled by the
hypothetical hacker through the computer system, vulnerability exists,
if the Dreamliner systems are similarly engineered.
Old January 9th 08, 08:05 PM posted to rec.aviation.piloting
wrote in :
attached to the flight controls.
Go **** yourself Netkkkop
Bertie
Old January 9th 08, 10:15 PM posted to rec.aviation.piloting
wrote in :
Never seen a system where the hydraulic pump was controlled; valves, yes,
pumps, no.
What would one "control"?
Jim Pennino
Remove .spam.sux to reply.
Old January 9th 08, 11:19 PM posted to rec.aviation.piloting
george
wrote in :
Oh lord no.
control surfaces.
alone.
It'll happen
I'm still considering the statement about flight controls that do not
connect to the control surfaces.
Almost good enough for a sig
What are Boeing's plans? Pooh Bear General Aviation 55 September 30th 04 07:59 PM
What are Boeing's plans? David Lednicer General Aviation 6 September 27th 04 09:19 PM
What are Boeing's plans? Pooh Bear Owning 12 September 27th 04 09:07 PM
What are Boeing's plans? Pooh Bear Owning 13 September 27th 04 06:05 AM
What are Boeing's plans? Larry Dighera Piloting 0 September 17th 04 11:57 AM
