Rockets used in al-Rashid hotel match "aluminum tubes" rockets
Old October 26th 03, 04:56 PM
Robb McLeod
Default Rockets used in al-Rashid hotel match "aluminum tubes" rockets
There's a picture of the type of rocket used in the attack on the
al-Rashid hotel where Wolfowitz was staying:
http://media.washingtonpost.com/wp-s...p10-26-03a.jpg
Just from the picture you can tell that the length to diameter ratio
of the rocket is 11:1. It's known that the "aluminum tubes" of
centrifuge infamy had the dimensions 81 x 900 mm, which matches the
size of the pictured rocket quite well.
It's generally accepted now that those tubes where actually intended
for helicopter fired rocket casings.
http://www.isis-online.org/publicati.../al_tubes.html
It's not a huge jump from the data to conclude that the rockets used
in yesterday's attack where in fact the knock offs of the Italian
Medusa-81 that Iraq was producing.
It's a dark piece of irony, but you have to assume that it was known
that Wolfowitz was in the hotel and the rocket was specifically chosen
to reopen old wounds and cause Wolfowitz some political discomfiture.
Robb McLeod )
A bus station is where a bus stops. A train station is where a train stops.
On my desk I have a work station...
Old October 27th 03, 01:38 AM
Jack Linthicum
Robb McLeod wrote in message . ..
Mayhap it was a 122mm artillery rocket, they seem to be in every
bunker opened in Iraq and were much used by the bad Viets in Vietnam.
Papers seem to think the things were RPGs.
http://www.landscaper.net/images/122mmrockt.jpg
Old October 27th 03, 04:51 AM
Don Harstad
"Robb McLeod" wrote in message
Actually, you don't have to assume that at all. They also resemble 122mm
rockets... but I don't think they were used to state the exquisite irony
that they might have been made from old lend/lease P-39 airframes....
Don H.
Old October 27th 03, 05:02 AM
Robb McLeod
On 26 Oct 2003 17:38:49 -0800, (Jack
snip
The fin design is different however, and that's a pretty hefty rocket
to be holding in one hand as the soldier is doing in the Washington
Post picture.
Robb McLeod )
Old October 27th 03, 12:15 PM
Jack Linthicum
snip
Post picture.
I must be totally blind, I can't see fins in that picture. The 122
fins fold into the end and the middle piece (the 122mm is made of two
sections plus the warhead) doesn't have fins at all. I have picked up
one of the loaded launch sections (with two hands, I am not nor ever
was a fool in these matters) easily. I would expect an 'empty' to
weight about 3-4 pounds at most.
On the other hand the paper says they were 68mm and 85mm rockets. I
get 68mm in the google (anti-personnel, perfect against a building)
but no 85 mm rockets. The 68mm's seem to be used from helicopters. The
RPG-7 warhead is listed as being 85mm in diameter, perhaps one answer.
Old October 27th 03, 03:21 PM
Howard Berkowitz
Aircraft rockets seem about right. I'd have expected more damage from 8
or so 122's, and the range was rather long for an RPG.
Old October 27th 03, 08:46 PM
phil hunt
If you look at
http://news.bbc.co.uk/1/hi/world/middle_east/3214901.stm
there's a picture of a rocket launcher inside a truck. There are 40
tubes, arranged as 4*10, the same as used in the Russian BM-21 122
mm MRL.
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
(Email: , but first subtract 275 and reverse
the last two letters).
Old October 28th 03, 07:49 AM
Seraphim
(Jack Linthicum) wrote in
m:
ratio of the rocket is 11:1.
of centrifuge infamy had the dimensions 81 x 900 mm, which matches
the size of the pictured rocket quite well.
intended for helicopter fired rocket casings.
Vietnam. Papers seem to think the things were RPGs.
According to CNN they were 68mm and 85mm
http://www.cnn.com/2003/WORLD/meast/...tel/index.html
Go down to the 3rd paragraph under the bold "Dempsey: Missile launcher
primitive but clever"
epoxy aircraft seats? Lpmcatee356 Home Built 26 December 3rd 03 11:16 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
