On Jan 16, 10:39 am, Mxsmanic wrote:
Travel is not my objective. In fact, it's one of the things I don't like about flying for real. One of the practical aspects of simulation is that I don't have to actually go anywhere when flying. I suppose you simulate work, trips to the dentist, and exercise since those are things you don't like? MSFS may be entertaining, or even quasi-informative, but "practical" is not an appropriate adjective. Speak for yourself. Asserting that flight simulation is "practical" for no apparent useful function is unreasonable. Dan |
On Jan 17, 3:20 am, " wrote:
"Useful" and "Practical" only apply in support of some other function. A manure shovel is not practical or useful in surgery, but it is very practical and useful in a barn or a newsgroup. Finally some-one has put the two together. Anthony and manure shovel operator |
Practical? It sure is, it's the most covenient way to get from here to
here. Or there to there. On Jan 16, 9:12*am, Mxsmanic wrote: writes: You can run one tank dry in a Bonanza and have the other at 35 gallons and only need 1/4 twist of the aileron trim to keep things balanced. 1/4 twist = 1/4 rotation of the knob (90 degrees of rotation)? If that's true, then I suppose the weight of the pilot must be far less significant in comparison. I doubt there is a Bonanza flying with a "Both" selection. I've seen pictures of selectors with a "both" position, although apparently they don't come that way from the factory. *Odd that such a position isn't standard. *Dreamfleet puts such a selector in its Bonanza (one of the very few departures from reality) because MSFS supposedly exaggerates fuel imbalances. I always leave it in that position. If you're "flying" in MSFS, the aerodynamic positive stability tendencies are exaggerated to make it less off putting for non-pilots. They may be for the default aircraft, but not necessarily for add-ons, which handle very differently from the default aircraft. *The best add-ons make such a large difference that it's like flying an entirely new simulator. I can always tell when I'm flying with a MSFS Pilot -- they flare high, fixate on the instruments, and have poor coordination. I can always tell when a real pilot of small aircraft is flying the sim, because he doesn't know what most of the instruments are for, can't fly safely in IMC, and can't land the plane without an accident because he depends on the seat of his pants for everything. The real value to a real pilot of MSFS is practicing certain (albeit limited) procedures, lesson preview and review, approach practice, and assistance in acquiring an ear for ATC communications. You're not really flying, though. It's good enough for me, and it's very practical. |
Mxsmanic wrote:
I've seen pictures of selectors with a "both" position, although apparently they don't come that way from the factory. Odd that such a position isn't standard. Dreamfleet puts such a selector in its Bonanza (one of the very few departures from reality) because MSFS supposedly exaggerates fuel imbalances. I always leave it in that position. Please point me to such a picture. I've never seen one. I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. |
Gig 601XL Builder wrote in
: Mxsmanic wrote: I've seen pictures of selectors with a "both" position, although apparently they don't come that way from the factory. Odd that such a position isn't standard. Dreamfleet puts such a selector in its Bonanza (one of the very few departures from reality) because MSFS supposedly exaggerates fuel imbalances. I always leave it in that position. Please point me to such a picture. I've never seen one. I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. Xactly. I know of an RV6 where they installed a selector with a both" position "in the interest of safety" How it got past the DAR I have no idea, but it crashed on it's second flight........ Bertie |
Gig 601XL Builder writes:
I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. Add a fuel pump. |
Mxsmanic wrote in
: Gig 601XL Builder writes: I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. Add a fuel pump. Moron. Bertie |
Hi,
In article , wrote: Gig 601XL Builder writes: I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. Add a fuel pump. You sucking provides the analog to the fuel pump. Andy |
Mxsmanic wrote:
Gig 601XL Builder writes: I want you to do an easy experiment that will show you the problem with a non gravity feed system that uses a "both" position. Take a glass of water and two drinking straws. Put one of the straws in the water and hold the other out side of the glass. Now put both straws in your mouth and suck. Unless you are doing something to block the straw that isn't in the water you will find it very hard to get a drink. The same thing happens with a non gravity feed fuel system in the "both" mode. Add a fuel pump. Where would you place the fuel pump to deal with the problem? |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight & Balance DVD | jon | Home Built | 0 | October 8th 05 05:39 PM |
Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 05:11 PM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
