.. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff |
Capt. Geoffrey Thorpe wrote:
"Bertie the Bunyip" wrote in message .. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff What gets them isn't really the turn per se, but the way that turn is flown. The combination of the increased stall speed due to the turn coupled with some excess inside rudder causing a skid as the stall breaks is a perfect pro-spin setup. The two ingredients for spin are present; stall and a yaw rate coupled simultaneously . You can get away with a tight low turn if it's coordinated and you feed in enough power to offset the drag rise; or even better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) but it's that lack of attention to the extra needed thrust as the drag rises in the turn and cheating a bit with inside rudder to "force that nose around that will get you killed. -- Dudley Henriques |
... Capt. Geoffrey Thorpe wrote: "Bertie the Bunyip" wrote in message .. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff What gets them isn't really the turn per se, but the way that turn is flown. The combination of the increased stall speed due to the turn coupled with some excess inside rudder causing a skid as the stall breaks is a perfect pro-spin setup. The two ingredients for spin are present; stall and a yaw rate coupled simultaneously . You can get away with a tight low turn if it's coordinated and you feed in enough power to offset the drag rise; or even better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) but it's that lack of attention to the extra needed thrust as the drag rises in the turn and cheating a bit with inside rudder to "force that nose around that will get you killed. -- Dudley Henriques Since I probably qualify as hopelessly unqualified, and also since both of you have already described this in different words, I should probably "keep my mouth shut"; but from all I have heard, things happen much more suddenly as part of an uncoordinated accellerated stall. I never personally got to explore the accellerated stall portion of the envelope, and only had an accellerated stall demonstrated to me once. That once was by a pilot who was so proficient, smooth and coordinated that the stall was a complete non-event and we simply flew out of it and continued the turn as though nothing had happened. And, yes, this was in a Cessna 152 that was appropriately certified for that sort of work. However, viewed in another manner, the guy (who was a high time instructor) would have been the perfect candidate to train new instrucors to let their students kill them... When I resume flying, as I plan to do, I also plan to more fully explore the accelerated stall area of the envelope--in an appropriate trainer of course. Peter |
Peter Dohm wrote:
"Dudley Henriques" wrote in message ... Capt. Geoffrey Thorpe wrote: "Bertie the Bunyip" wrote in message .. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff What gets them isn't really the turn per se, but the way that turn is flown. The combination of the increased stall speed due to the turn coupled with some excess inside rudder causing a skid as the stall breaks is a perfect pro-spin setup. The two ingredients for spin are present; stall and a yaw rate coupled simultaneously . You can get away with a tight low turn if it's coordinated and you feed in enough power to offset the drag rise; or even better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) but it's that lack of attention to the extra needed thrust as the drag rises in the turn and cheating a bit with inside rudder to "force that nose around that will get you killed. -- Dudley Henriques Since I probably qualify as hopelessly unqualified, and also since both of you have already described this in different words, I should probably "keep my mouth shut"; but from all I have heard, things happen much more suddenly as part of an uncoordinated accellerated stall. I never personally got to explore the accellerated stall portion of the envelope, and only had an accellerated stall demonstrated to me once. That once was by a pilot who was so proficient, smooth and coordinated that the stall was a complete non-event and we simply flew out of it and continued the turn as though nothing had happened. And, yes, this was in a Cessna 152 that was appropriately certified for that sort of work. However, viewed in another manner, the guy (who was a high time instructor) would have been the perfect candidate to train new instrucors to let their students kill them... When I resume flying, as I plan to do, I also plan to more fully explore the accelerated stall area of the envelope--in an appropriate trainer of course. Peter Good idea. Reason for this is that the majority of accidental stall incidents will be accelerated. It takes a pilot seriously asleep to gently allow an airplane to stall accidentally at power off and 1g. Accelerated stall is an area of flight that all pilots should be completely familiar with. I spent MUCH more time with accelerated stall than simple power off stalls at 1g with every student I taught to fly. I only wish all instructors did the same. -- Dudley Henriques |
![]() "Dudley Henriques" wrote: better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) Why not, Dudley? This is a maneuver I use quite often because I like to make power-off landings. Am I on the verge of augering in without realizing it? -- Dan T-182T at BFM |
Dan Luke wrote:
"Dudley Henriques" wrote: better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) Why not, Dudley? This is a maneuver I use quite often because I like to make power-off landings. Am I on the verge of augering in without realizing it? Good question. Let me explain. In posting on the forums where student pilots might be involved, when discussing things like unloaded descending turns from base to final, I try not to post comments without a "warning" of some kind. The reason I do this is that although well trained pilots can and indeed make turnds like this all day long in perfect safety, they are still in the category of a tight turn made at low altitude and I don't want anyone getting hurt trying to something based on what I have said on a forum. Becoming capable to make a turn like we are discussing is part of a pilot's training that should be accomplished in the airplane with a competent instructor there on the job to make sure the pilot learns how to make such a turn properly. Once this is accomplished, most pilots won't even think about making that turn. They will know from where they are in the pattern, how tight the turn has to be, and whether or not the conditions are within safe parameters or outside safe parameters. In other words, it's safe enough if done properly as I'm sure you are aware, but only after a thorough examination of the factors involved. Just as an aside; I always covered late base to final turns with my own students before solo! -- Dudley Henriques |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote I watched two guys die after doing that on a tight, low, turn to a short final... Someone did that at OSH a few years back. 2001? -- Jim in NC |
On Jan 17, 8:06 pm, "Morgans" wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote I watched two guys die after doing that on a tight, low, turn to a short final... Someone did that at OSH a few years back. 2001? -- Jim in NC And another in Arlington in about '97. I saw that. One guy dead. Fooling around with a big ultralight, taking off short, climbing steeply and making a rather steep turn to return to the runway. Did this several times until it went bad. Dan |
spins from coordinated flight | Todd W. Deckard | Piloting | 61 | December 29th 07 01:28 AM |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
Spins in Libelles 301 & 201 | HL Falbaum | Soaring | 9 | February 10th 04 06:12 PM |
Thanks for the Spins Rich | David B. Cole | Aerobatics | 17 | October 26th 03 08:37 AM |
