On Wed, 16 Jan 2008 19:41:03 GMT, "Jim Carter"
wrote: "Robert M. Gary" wrote in message ... ... No, several planes did land. -Robert I think you're confusing with practicality with legality. OVC represents an overcast which represents a ceiling. 001 OVC is 100' ceiling which is less than any of the published minimums. 1/8 SM represents a visibility and on the ground that is less than RVR 2400 or any of the other published minimums. Planes landing have nothing to do with legality if someone breaks something here. Your original question was why the controller used "landing runway 22" instead of "cleared to land". You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility You are not allowed to break something in the process. If the controller cleared you to land wouldn't he or she possibly share some culpability? My point has always been that the reason the controller used this phrase was due to minimums, not your ability to land in fog. |
![]() wrote in message ... On Wed, 16 Jan 2008 19:41:03 GMT, "Jim Carter" wrote: "Robert M. Gary" wrote in message ... ... No, several planes did land. -Robert I think you're confusing with practicality with legality. OVC represents an overcast which represents a ceiling. 001 OVC is 100' ceiling which is less than any of the published minimums. 1/8 SM represents a visibility and on the ground that is less than RVR 2400 or any of the other published minimums. Planes landing have nothing to do with legality if someone breaks something here. Your original question was why the controller used "landing runway 22" instead of "cleared to land". You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. Al G |
it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. FAR 91.175 is pretty clear that the prescribed flight visibility is required to land: (d) Landing. No pilot operating an aircraft, except a military aircraft of the United States, may land that aircraft when— (1) [refers to use of enhanced vision systems]; or (2) For all other part 91 operations and parts 121, 125, 129, and 135 operations, the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used. Also, as I've already posted, 91.175(c) prohibits even continuing below DH unless you have the prescribed visibility. |
![]() "Barry" wrote in message . .. You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. FAR 91.175 is pretty clear that the prescribed flight visibility is required to land: (d) Landing. No pilot operating an aircraft, except a military aircraft of the United States, may land that aircraft when— (1) [refers to use of enhanced vision systems]; or (2) For all other part 91 operations and parts 121, 125, 129, and 135 operations, the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used. Also, as I've already posted, 91.175(c) prohibits even continuing below DH unless you have the prescribed visibility. My apologies, I thought you were talking about the Prevailing Visibility, as reported by the tower. The flight visibility, is determined by the pilot. The tower can be calling it 1/8 mile, RVR 600', but if I can see the environment from the DH, I have demonstrated 1/2 mile flight vis. Fog Seeder extraordinaire Al G |
On Jan 17, 11:28 am, "Al G" wrote:
"Barry" wrote in message . .. You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. FAR 91.175 is pretty clear that the prescribed flight visibility is required to land: (d) Landing. No pilot operating an aircraft, except a military aircraft of the United States, may land that aircraft when-- (1) [refers to use of enhanced vision systems]; or (2) For all other part 91 operations and parts 121, 125, 129, and 135 operations, the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used. Also, as I've already posted, 91.175(c) prohibits even continuing below DH unless you have the prescribed visibility. My apologies, I thought you were talking about the Prevailing Visibility, as reported by the tower. The flight visibility, is determined by the pilot. The tower can be calling it 1/8 mile, RVR 600', but if I can see the environment from the DH, I have demonstrated 1/2 mile flight vis. But there is no requirement you see the environment from the DH, only the approach lights. -Robert, CFII |
the approach lights. Correct, but as I've posted before, if you can't see almost to the threshold at DH (assuming 200 feet), you probably do not have the required visibility of 1/2 mile. |
Approach lights are part of runway environment...
On Thu, 17 Jan 2008 11:39:46 -0800 (PST), "Robert M. Gary" wrote: On Jan 17, 11:28 am, "Al G" wrote: "Barry" wrote in message . .. You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. FAR 91.175 is pretty clear that the prescribed flight visibility is required to land: (d) Landing. No pilot operating an aircraft, except a military aircraft of the United States, may land that aircraft when-- (1) [refers to use of enhanced vision systems]; or (2) For all other part 91 operations and parts 121, 125, 129, and 135 operations, the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used. Also, as I've already posted, 91.175(c) prohibits even continuing below DH unless you have the prescribed visibility. My apologies, I thought you were talking about the Prevailing Visibility, as reported by the tower. The flight visibility, is determined by the pilot. The tower can be calling it 1/8 mile, RVR 600', but if I can see the environment from the DH, I have demonstrated 1/2 mile flight vis. But there is no requirement you see the environment from the DH, only the approach lights. -Robert, CFII |
On Jan 17, 8:48*pm, wrote:
Approach lights are part of runway environment... Then you are clearly wrong. The fact that you see the approach lights certainly does not indiciate that you have any visibility. As I mentioned before you can see the approach lights through the fog but not be able to see the ground around the lights. So your statement that seeing the environment demonstrates the visibility, if you include the apporach lights, cannot be correct. -robert, CFII |
"Barry" wrote in
: You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. FAR 91.175 is pretty clear that the prescribed flight visibility is required to land: (d) Landing. No pilot operating an aircraft, except a military aircraft of the United States, may land that aircraft when— (1) [refers to use of enhanced vision systems]; or (2) For all other part 91 operations and parts 121, 125, 129, and 135 operations, the flight visibility is less than the visibility prescribed in the standard instrument approach procedure being used. Also, as I've already posted, 91.175(c) prohibits even continuing below DH unless you have the prescribed visibility. Yeah, but you get to decide if it's adequate at DH Bertie |
![]() There are three conditions for descending below MDA or continuing an approach beyond DA: 1) Runway environment in sight 2) Continuously in position to descend, etc... 3) Have the established flight visibility On Thu, 17 Jan 2008 09:44:38 -0800, "Al G" wrote: wrote in message .. . On Wed, 16 Jan 2008 19:41:03 GMT, "Jim Carter" wrote: "Robert M. Gary" wrote in message ... ... No, several planes did land. -Robert I think you're confusing with practicality with legality. OVC represents an overcast which represents a ceiling. 001 OVC is 100' ceiling which is less than any of the published minimums. 1/8 SM represents a visibility and on the ground that is less than RVR 2400 or any of the other published minimums. Planes landing have nothing to do with legality if someone breaks something here. Your original question was why the controller used "landing runway 22" instead of "cleared to land". You are correct that as a Part 91 flight you can begin the approach even if it is reported Zero-Zero, and you are allowed to land if you have the runway environment in site when you reach the decision point on the approach. You must also have the prescribed flight visibility Nope, just the runway environment. Al G |
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" | Mike[_7_] | Naval Aviation | 50 | November 30th 07 05:25 AM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
"Airplane Drivers" and "Self Centered Idiots" | Skylune | Piloting | 28 | October 16th 06 05:40 AM |
Desktop Wallpaper - "The "Hanoi Taxi"". | T. & D. Gregor, Sr. | Simulators | 0 | December 31st 05 06:59 PM |
