On Jan 17, 9:15 pm, "Robert M. Gary" wrote:
I only teach in Monneys but I'm not sure why you would need to be faster without flaps. Even if I used flaps I wouldn't change the speed on the approach. Are you flying ILSs in a 172 at 50 knots such that you need flaps? Nope --100-90 KIAS in an A36, 90 KIAS in a 172. Approach flaps set in the A36 and 10 degrees in 172. But either way you have full flaps once you go visual so the landings distance is the same in each technique. While that may be the case in a particular Mooney or Cherokee or Skyhawk, this method will not work in a faster (more slippery) airplane. Try this next time -- see what happens to the ILS needles when your student drops full flaps once the runway is in sight. Once you're visual holding the needles in the middle is trivial because you are looking at the runway. Do you ever practice ILS all the way down to touchdown? If not, you may want to try it -- it's a good confidence boost. Dan |
On Jan 18, 5:26*am, " wrote:
On Jan 17, 9:15 pm, "Robert M. Gary" wrote: I only teach in Monneys but I'm not sure why you would need to be faster without flaps. Even if I used flaps I wouldn't change the speed on the approach. Are you flying ILSs in a 172 at 50 knots such that you need flaps? Nope --100-90 KIAS in an A36, 90 KIAS in a 172. Approach flaps set in the A36 and 10 degrees in 172. I never noticed that as a problem in the A36. It was very stable at 100 knots without flaps. I never felt any tendancy for it to be unstable. But either way you have full flaps once you go visual so the landings distance is the same in each technique. While that may be the case in a particular Mooney or Cherokee or Skyhawk, this method will not work in a faster (more slippery) airplane. What plane are you flying that is more slippery than a Mooney and that does not slow when you deploy the flaps? Your A36 is a truck compared to the slippery Mooney. I used to cook into San Jose Int'l in the A36 at 150 knots and drop the gear/flaps on short final. I could feel the G's of the decelleration, so you can't tell me that your A36 won't slow with flaps. -Robert |
On Jan 18, 2:05 pm, "Robert M. Gary" wrote:
What plane are you flying that is more slippery than a Mooney and that does not slow when you deploy the flaps? Your A36 is a truck compared to the slippery Mooney. I used to cook into San Jose Int'l in the A36 at 150 knots and drop the gear/flaps on short final. I could feel the G's of the decelleration, so you can't tell me that your A36 won't slow with flaps. -Robert The A56 drag coefficient is a bit more than a Lear and an F-104, so it's pretty slippery. In the Army we differentiated between doctrine and technique. Doctrine everybody was to do, period. Technique was the method you employed to achieve doctrine. In this case "doctrine" is to arrive at the runway with as little energy as possible, given the requirements of safety in the conditions at hand. If you can reconfigure the airplane on short final and reduce the speed as appropriate to achieve this, then that's your technique. But I think teaching this particular method as the only way for every airplane is a mistake, as it will eventually lead to overly fast landings when the student climbs aboard his/her faster airplane. It just seems to me that a consistent, less drastic change in configuration is the better technique. Dan |
On Jan 18, 6:32*pm, " wrote:
The A56 drag coefficient is a bit more than a Lear and an F-104, so it's pretty slippery. True, but its still a truck compared to a Mooney. But I think teaching this particular method as the only way for every airplane is a mistake, as it will eventually lead to overly fast landings when the student climbs aboard his/her faster airplane. I think anyone who teaches either technique and claims its good for all aircraft is probably full of crap. I wouldn't teach flying approaches w/o flaps in a 767. When I'm giving training in the Mooney or occasionally in the A36 people are looking for type specific training. Showing them how its done in other aircraft (like a 767) is not what they are looking for. In both those aircraft I find the no flap approach best. Add to that that I live in a fog valley and finding nothing but 0/0 at mins is not uncommon so shooting approaches to mins in actual is not theory around here and neither are missed in actual. -Robert |
On Jan 18, 9:37 pm, "Robert M. Gary" wrote:
On Jan 18, 6:32 pm, " wrote: The A56 drag coefficient is a bit more than a Lear and an F-104, so it's pretty slippery. True, but its still a truck compared to a Mooney. But I think teaching this particular method as the only way for every airplane is a mistake, as it will eventually lead to overly fast landings when the student climbs aboard his/her faster airplane. I think anyone who teaches either technique and claims its good for all aircraft is probably full of crap. I wouldn't teach flying approaches w/o flaps in a 767. When I'm giving training in the Mooney or occasionally in the A36 people are looking for type specific training. Showing them how its done in other aircraft (like a 767) is not what they are looking for. In both those aircraft I find the no flap approach best. Add to that that I live in a fog valley and finding nothing but 0/0 at mins is not uncommon so shooting approaches to mins in actual is not theory around here and neither are missed in actual. -Robert Well then there ya go... Dan |
On Jan 18, 6:32 pm, " wrote: The A56 drag coefficient is a bit more than a Lear and an F-104, so it's pretty slippery. True, but its still a truck compared to a Mooney. But I think teaching this particular method as the only way for every airplane is a mistake, as it will eventually lead to overly fast landings when the student climbs aboard his/her faster airplane. I think anyone who teaches either technique and claims its good for all aircraft is probably full of crap. I wouldn't teach flying approaches w/o flaps in a 767. When I'm giving training in the Mooney or occasionally in the A36 people are looking for type specific training. Showing them how its done in other aircraft (like a 767) is not what they are looking for. In both those aircraft I find the no flap approach best. Add to that that I live in a fog valley and finding nothing but 0/0 at mins is not uncommon so shooting approaches to mins in actual is not theory around here and neither are missed in actual. -Robert So, you are able to: Apply full flaps Reduce speed from 90-100 K to 70 K Continue descending to the touchdown point Stabilize the approach at somewhere near 1.3-1.4 Vso All beginning at 200' AGL? Dan |
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" | Mike[_7_] | Naval Aviation | 50 | November 30th 07 05:25 AM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
"Airplane Drivers" and "Self Centered Idiots" | Skylune | Piloting | 28 | October 16th 06 05:40 AM |
Desktop Wallpaper - "The "Hanoi Taxi"". | T. & D. Gregor, Sr. | Simulators | 0 | December 31st 05 06:59 PM |
