Engine Baffling Supplier
Old January 21st 08, 02:41 PM posted to rec.aviation.owning
Mike Spera
Default Engine Baffling Supplier
As the 74 Cherokee ages, the engine baffling (0-320 E3D) is starting to
show its age. Various places have been stop drilled over the years and
it is time for replacement.
I really don't want used salvage parts because they are likely in the
same condition as what I have. The intercylinder baffles and hooks
appear to be Lycoming manufactured hardware and ECI makes inexpensive
replacements. Those don't need replacing (readily available, reasonably
priced PMA alternatives - of COURSE you don't need THOSE).
However, the outer shrouding that needs replacing appears to be Piper
designed/supplied. Where can you get this stuff new so that the 2-3
pieces I need won't cost as much as a new engine? 1 piece from the
DesMoines Flight Service database lists for
$885.00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Any sources?
Thanks,
Mike
Old January 21st 08, 02:59 PM posted to rec.aviation.owning
Bob Noel
Is there enough of it left that you can fabricate it yourself (using acceptable
materials and methods)?
When I overhauled my 140, the A&Ps had me make some replacement
parts for the baffling.
Bob Noel
(goodness, please trim replies!!!)
Old January 21st 08, 07:45 PM posted to rec.aviation.owning
Mike Spera
Actually, Most of it is fine. I just have a couple of pieces that have
cracked here and there. I suppose I could just fabricate some repair
pieces in a pinch. I was just wondering if there was a source for new
ones that I had not heard of.
Thanks,
Mike
Old January 21st 08, 11:43 PM posted to rec.aviation.owning
Kyle Boatright
"Mike Spera" wrote in message
show its age. Various places have been stop drilled over the years and it
I really don't want used salvage parts because they are likely in the same
condition as what I have. The intercylinder baffles and hooks appear to be
Lycoming manufactured hardware and ECI makes inexpensive replacements.
Those don't need replacing (readily available, reasonably priced PMA
designed/supplied. Where can you get this stuff new so that the 2-3 pieces
I need won't cost as much as a new engine? 1 piece from the DesMoines
Any sources?
Thanks,
Mike
Find an RV builder in your area and look at the baffles in his/her airplane.
The entire baffle "kit" is roughly $200. My guess is that you could make the
parts fit and could claim them as owner fabricated replacement parts.
KB
Old January 22nd 08, 12:12 PM posted to rec.aviation.owning
Denny
Any sources?
Thanks,
Mike
KB- Hide quoted text -
- Show quoted text -
Claim, schmame - IRAN - make the needed "repairs" and install... Each
separate piece is simply a repair of the baffling system... Needs only
the barest of mentions by the A&I...
Fat Albert is going to get an engine overhaul (when crusty old
mechanic gets a round tuit)... Also planned is IRAN the baffles...
They will be gorgeous when done...
denny
denny
Old January 24th 08, 11:31 PM posted to rec.aviation.owning
Ray Andraka
airplane. The entire baffle "kit" is roughly $200. My guess is that you
could make the parts fit and could claim them as owner fabricated
replacement parts.
KB
Owner fabricated parts doesn't give you license to make the part however
you want to make it. Owner fabricated parts still have to meet the
original type certificate. That means either working from drawings or
reverse engineering the existing, making sure you match not only the
materials but also any manufacturing process that may alter the material
properties, e.g. heat treating. The final part must still be a faithful
duplicate of the part you are replacing. All the owner fabrication rule
does is get you around having a PMA approval on the part.
Old January 25th 08, 12:02 AM posted to rec.aviation.owning
Kyle Boatright
"Ray Andraka" wrote in message
replacement parts.
KB
My point, perhaps not communicated well, was that the Original Poster might
be able to buy Van's baffle kit and use it as a starting point. I'd guess
that Van's baffle kit is a very close match to anything supplied by Cessna,
Beech, Piper, etc. for a similar engine. Beats the heck out of starting
from scratch.
Beyond that, we're talking baffles, not having the OP machine new connecting
rods for his engine. Baffles are pretty simple and the OP should be able to
make a determination as to whether the kit part would or wouldn't work.
KB
Fiberglass Wheel Pants Supplier? JB Owning 1 October 19th 04 04:28 AM
need link for SS rivet supplier Charles S Home Built 1 May 9th 04 02:34 AM
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? jls Home Built 3 February 3rd 04 12:15 AM
Amsteel Blue Supplier Sweeny Soaring 1 October 31st 03 12:46 PM
ADV: MIle High supplier David Campbell Soaring 0 August 7th 03 02:16 AM
