" wrote in
: On Jan 23, 9:12 am, Bertie the Bunyip wrote: " wrote in news:28fafb4c-f37c-4f9f- : On Jan 23, 12:56 am, Bertie the Bunyip wrote: Hm, well, the Aerodynamics for Naval Aviators" was a bit over my head at the time and the instrument flying one was a bit confusing with the pics of giants holding up the wings of Wildcats! I read through it for the first time (prior I had picked my way through) while watching the NFC and AFC playoffs this Sunday. It was the perfect 10 minutes at a time read -- more than that and it was just too much info to process. Most was a review of things I had read elsewhere, but written in a much more succinct and authoritative manner. The landing performance section confirmed earlier posts about arriving at the runway with minimal energy -- 1.3-1.5 Vso. Seems as if this rule would be doubly critical to conventional gear. Well, yeah, becase you generaly three point them anyway, arriving with any more than that just extends your flare. It's not what I'd call critical, more pointless. Bertie Well, isn't it critical in the sense that excess speed increases the possibility of a ground loop? ell, not if you land three point. If you land three point the speed is pretty much always exactly the same for a given weight. For a wheel landing, though, you'd be correct, if the wheel landing was done by driving the airplane onto the ground, which would be poor technique. A wheel lnding should also be made in the same attitude each tie and that will give you the same touchdown speed eahc time regardless of the approach speed. You will float, though! Bertie |
On Wed, 23 Jan 2008 15:33:28 +0000 (UTC), Bertie the Bunyip
wrote: " wrote in : On Jan 23, 9:12 am, Bertie the Bunyip wrote: " wrote in news:28fafb4c-f37c-4f9f- : On Jan 23, 12:56 am, Bertie the Bunyip wrote: Hm, well, the Aerodynamics for Naval Aviators" was a bit over my head at the time and the instrument flying one was a bit confusing with the pics of giants holding up the wings of Wildcats! I read through it for the first time (prior I had picked my way through) while watching the NFC and AFC playoffs this Sunday. It was the perfect 10 minutes at a time read -- more than that and it was just too much info to process. Most was a review of things I had read elsewhere, but written in a much more succinct and authoritative manner. The landing performance section confirmed earlier posts about arriving at the runway with minimal energy -- 1.3-1.5 Vso. Seems as if this rule would be doubly critical to conventional gear. Well, yeah, becase you generaly three point them anyway, arriving with any more than that just extends your flare. It's not what I'd call critical, more pointless. Bertie Well, isn't it critical in the sense that excess speed increases the possibility of a ground loop? ell, not if you land three point. If you land three point the speed is pretty much always exactly the same for a given weight. For a wheel landing, though, you'd be correct, if the wheel landing was done by driving the airplane onto the ground, which would be poor technique. A wheel lnding should also be made in the same attitude each tie and that will give you the same touchdown speed eahc time regardless of the approach speed. You will float, though! Bertie you can improve on that. the secret to a successful landing is to have the longitudinal axis of the aircraft aligned in the direction of flight, to have no sideslip, to have no vertical speed at the point of touchdown and to have no excess of speed. if you have any excess of speed and some vertical speed on touchdown, unless your tyres are pretty flat, you'll bounce back into the air in a balloon. guaranteed. speed does not increase the possibility of a groundloop if the aircraft is kept aligned with the direction of flight. Stealth (tailwind) Pilot |
Stealth Pilot wrote in
: On Wed, 23 Jan 2008 15:33:28 +0000 (UTC), Bertie the Bunyip wrote: " wrote in : On Jan 23, 9:12 am, Bertie the Bunyip wrote: " wrote in news:28fafb4c-f37c-4f9f- : On Jan 23, 12:56 am, Bertie the Bunyip wrote: Hm, well, the Aerodynamics for Naval Aviators" was a bit over my head at the time and the instrument flying one was a bit confusing with the pics of giants holding up the wings of Wildcats! I read through it for the first time (prior I had picked my way through) while watching the NFC and AFC playoffs this Sunday. It was the perfect 10 minutes at a time read -- more than that and it was just too much info to process. Most was a review of things I had read elsewhere, but written in a much more succinct and authoritative manner. The landing performance section confirmed earlier posts about arriving at the runway with minimal energy -- 1.3-1.5 Vso. Seems as if this rule would be doubly critical to conventional gear. Well, yeah, becase you generaly three point them anyway, arriving with any more than that just extends your flare. It's not what I'd call critical, more pointless. Bertie Well, isn't it critical in the sense that excess speed increases the possibility of a ground loop? ell, not if you land three point. If you land three point the speed is pretty much always exactly the same for a given weight. For a wheel landing, though, you'd be correct, if the wheel landing was done by driving the airplane onto the ground, which would be poor technique. A wheel lnding should also be made in the same attitude each tie and that will give you the same touchdown speed eahc time regardless of the approach speed. You will float, though! Bertie you can improve on that. the secret to a successful landing is to have the longitudinal axis of the aircraft aligned in the direction of flight, to have no sideslip, to have no vertical speed at the point of touchdown and to have no excess of speed. if you have any excess of speed and some vertical speed on touchdown, unless your tyres are pretty flat, you'll bounce back into the air in a balloon. guaranteed. speed does not increase the possibility of a groundloop if the aircraft is kept aligned with the direction of flight. Mmmmm, true enough. if you're on top of it it's nto going anywhere. It's probably more accurate, or maybel helpful is the wird, to state that excess speed will imart more energy to a ground loop if you let one develop. The groundloop will be more violent if you are traveling faster when it begins. It's beside the point, though, since if you touch down in the corrct attitude, the speed at touchdown will always be the same for a given weight, reardless of the approach speed. You'll just spend a lot longer in the flare! Bertie |
FA: TWA STARLINER~1946~Bound Volume~Trans World Airline~scarce | [email protected] | Aviation Marketplace | 0 | February 7th 07 10:45 PM |
Wanted: Bulkhead for 1946 Navion A Continental E-225 | A-Hall | Restoration | 0 | June 6th 06 09:11 PM |
WTB:135 Ticket | AML | Owning | 1 | May 24th 06 08:41 PM |
FS: 1946 Aeronca 7BCM that Needs Recovering | [email protected] | Aviation Marketplace | 0 | December 29th 05 11:41 PM |
Iran crisis 1946 and Yugoslavia | Vic Flintham | Military Aviation | 1 | December 13th 03 10:50 AM |
