Engine Baffling Supplier
Old January 24th 08, 11:31 PM posted to rec.aviation.owning
Ray Andraka
Default Engine Baffling Supplier
Find an RV builder in your area and look at the baffles in his/her
airplane. The entire baffle "kit" is roughly $200. My guess is that you
could make the parts fit and could claim them as owner fabricated
replacement parts.
KB
Owner fabricated parts doesn't give you license to make the part however
you want to make it. Owner fabricated parts still have to meet the
original type certificate. That means either working from drawings or
reverse engineering the existing, making sure you match not only the
materials but also any manufacturing process that may alter the material
properties, e.g. heat treating. The final part must still be a faithful
duplicate of the part you are replacing. All the owner fabrication rule
does is get you around having a PMA approval on the part.
Old January 25th 08, 12:02 AM posted to rec.aviation.owning
Kyle Boatright
"Ray Andraka" wrote in message
replacement parts.
KB
My point, perhaps not communicated well, was that the Original Poster might
be able to buy Van's baffle kit and use it as a starting point. I'd guess
that Van's baffle kit is a very close match to anything supplied by Cessna,
Beech, Piper, etc. for a similar engine. Beats the heck out of starting
from scratch.
Beyond that, we're talking baffles, not having the OP machine new connecting
rods for his engine. Baffles are pretty simple and the OP should be able to
make a determination as to whether the kit part would or wouldn't work.
KB
Fiberglass Wheel Pants Supplier? JB Owning 1 October 19th 04 04:28 AM
need link for SS rivet supplier Charles S Home Built 1 May 9th 04 02:34 AM
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? jls Home Built 3 February 3rd 04 12:15 AM
Amsteel Blue Supplier Sweeny Soaring 1 October 31st 03 12:46 PM
ADV: MIle High supplier David Campbell Soaring 0 August 7th 03 02:16 AM
