Note a book but...
http://www.risingup.com/planespecs/ Just remember (as has been noted here on past occasions) that the data in this webpage is often laughably inaccurate. The page on the Pathfinder, for example, lists a "62 gallon" fuel capacity. The correct answer is either 50 (without tip tanks; although I don't believe any were built *without* tip tanks, but I could be wrong) or 84 gallons with tip tanks. When they get basic stuff like that wrong, I tend to lose faith in the rest of the data. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Note a book but... http://www.risingup.com/planespecs/ Just remember (as has been noted here on past occasions) that the data in this webpage is often laughably inaccurate. The page on the Pathfinder, for example, lists a "62 gallon" fuel capacity. The correct answer is either 50 (without tip tanks; although I don't believe any were built *without* tip tanks, but I could be wrong) or 84 gallons with tip tanks. When they get basic stuff like that wrong, I tend to lose faith in the rest of the data. You are correct. I just looked at my aircraft and it lists 42 gal. I believe it is 39 with 1.5 unusable each wing. -- Regards, Ross C-172F 180HP KSWI |
Cessna's next piston single | [email protected] | Owning | 0 | February 11th 06 07:14 PM |
IFR w/pax under Single-Pilot/Single Aircraft 135 | Bravo8500 | Owning | 20 | March 9th 05 09:37 PM |
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! | David Ross | Aviation Marketplace | 0 | August 24th 04 07:13 PM |
Cessna's new piston single. | Dan Luke | Piloting | 3 | July 7th 04 12:54 AM |
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? | NoSpam | Piloting | 31 | January 9th 04 01:45 AM |
