Notam re. Blanik ?
Old January 28th 08, 03:11 PM posted to rec.aviation.soaring
no-top@post
Default Notam re. Blanik ?
I'm told by my club that we can't use the Blanik until
the 'problem notified by the factory' is attended to.
Since apparently there are more Blaniks than other
gliders in the world, I was expecting a bunch of
posts related to this matter.
Why do I see none ?
Old January 28th 08, 03:43 PM posted to rec.aviation.soaring
Nyal Williams
What problem?
Why do I see none ?
Old January 28th 08, 04:29 PM posted to rec.aviation.soaring
Frank Whiteley
On Jan 28, 9:43 am, Nyal Williams
What problem?
Why do I see none ?
There was a recent thread for US consumption.
Date: Mon, 3 Dec 2007 23:41:33 -0800 (PST)
Local: Tues, Dec 4 2007 1:41 am
Subject: Blanik L-13 AD
Reply | Reply to author | Forward | Print | Individual message | Show
original | Report this message | Find messages by this author
There is a new AD on all models and all serial #'s of Blanik L-13's.
It will take effect on Jan. 08, 2008 and the compliance period is
three months from that date. Check Docket No. FAA-2007-28980
Directorate Identifier 2007-CE-071-AD; Amendment 39-15282; AD
2007-25-01
You may examine the AD docket on the Internet at:
Http://www.regulations.gov
Tom
Idaho
Date: Tue, 4 Dec 2007 04:29:01 -0800 (PST)
Local: Tues, Dec 4 2007 6:29 am
Blanik L-13 AD for Repetitive Inspection. AD effective JAN 2008.
(FAA) . . . issued a notice of proposed rulemaking (NPRM) to amend
14 CFR
part 39 to include an AD that would apply to the specified products.
That NPRM was published in the Federal Register on October 4, 2007
(72
FR 56700). That NPRM proposed to correct an unsafe condition for the
specified products. The MCAI states:
This Airworthiness Directive (AD) is prompted by the discovery
of cracks on L13 BLANIK sailplanes in zones where the forward and
aft control sticks are attached to the connecting rod, designated as
``control bridge'' in the relevant Illustrated Parts Catalogues
(IPC). If left uncorrected, cracks could propagate and lead to
failure of the connecting rod with subsequent loss of control of the
sailplane.
For the reasons described above, this AD requires an inspection
of the control bridge to detect cracks and replacement, if
necessary. In addition, this AD requires an update of the aircraft
Maintenance Manual (MM) to incorporate repetitive inspections of the
control bridge.
Old January 29th 08, 07:26 AM posted to rec.aviation.soaring
problems@gmail
Default Re (2): Notam re. Blanik ?
In article , Frank Whiteley wrote:
Why do I see none ?
--snip --
Tom
Idaho
Thanks !
== Chris Glur.
Old January 29th 08, 09:36 AM posted to rec.aviation.soaring
Bruce
Why do I see none ?
--snip --
Tom
Idaho
Thanks !
== Chris Glur.
Since we picked this up a little late all South African Blaniks were grounded
till the compulsory TN from the manufacturer has been complied with.
It only takes about two hours of advanced screwdriver wielding to get all the
fasteners out so you can remove the bridge...
Clearly labour time was not a consideration when this one was designed.
Old January 29th 08, 04:20 PM posted to rec.aviation.soaring
Nyal Williams
Note that Blanik does not mean SuperBlanik -- a distinction
most of us don't make.
Why do I see none ?
--snip --
Tom
Idaho
Thanks !
== Chris Glur.
complied with.
one was designed.
Old February 3rd 08, 07:21 PM posted to rec.aviation.soaring
BT
Only the L-13s are affected by this.. the L-23 "Super" and L-33 "Solo" are
not.
BT
"Nyal Williams" wrote in message
Why do I see none ?
--snip --
Tom
Idaho
Thanks !
== Chris Glur.
complied with.
one was designed.
OSH NOTAM question Dan Luke Piloting 1 July 23rd 05 03:48 PM
GPS PRN NOTAM Ali Ghorashi Instrument Flight Rules 7 February 4th 05 07:40 AM
NOTAM C J Campbell Piloting 87 October 15th 04 06:03 PM
MRB DP NOTAM [email protected] Instrument Flight Rules 12 March 11th 04 05:19 PM
AF/D's and NOTAM Andrew Sarangan Instrument Flight Rules 9 January 19th 04 09:19 PM
