Sounds a bit more sophisticated than putting up waterspouts!
As I recall, Yamato did sortie, so presumably it did fire some guns, though that is hardly certain. It could have been a species of proactive scuttling. "As were most Japanese warships, the Yamato and Musashi were provided with a special anti-aircraft incendiary shrapnel shell officially designated as "Type 3 Common" but nicknamed "San Shiki" (The Beehive). This round weighed 2,998 lbs. (1,360 kg) and was filled with 900 incendiary tubes made out of rubber thermite and 600 steel stays. A time fuze was used to set the desired exploding distance, usually about 1,000 meters (1,100 yards). These projectiles were designed to burst in a 20 degree cone extending towards the oncoming aircraft with the projectile shell itself being destroyed by a bursting charge to increase the quantity of steel splinters. The incendiary tubes ignited about half a second later and burned for five seconds at 3,000 degrees C, producing a flame about 5 meters (16 feet) long. " Keith all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver writes:
As I recall, Yamato did sortie, so presumably it did fire some guns, Japanese accounts that I have read mention that the weather was so poor, with low cloud, that the attacking aircraft could not be seen until they were already far too close to be engaged by the main battery. The overwhelming importance of radar for ships against aircraft.... -- G Hassenpflug * IJN & JMSDF equipment/history fan |
russia vs. japan in 1941 [WAS: 50% of NAZI oil..] | Military Aviation | 136 | December 6th 03 10:40 PM | |
OT- north korean nuke weapon plutonium - source? | patrick mitchel | Military Aviation | 11 | August 31st 03 04:01 AM |
AIRCRAFT MUNITIONS - THE COBALT BOMB | Garrison Hilliard | Military Aviation | 1 | August 29th 03 09:22 AM |
Japanese Army Navy | Keith Willshaw | Military Aviation | 35 | July 29th 03 03:22 AM |
Rapists and Robbers have a New Weapon | Bumper7 | Aerobatics | 0 | July 17th 03 09:37 AM |
