![]() Mxsmanic wrote: Is it a bad idea to fly VFR at night and navigate by following highways? My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. -c |
gatt wrote:
Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. I followed a highway up to Alaska. In daylight,however. |
gatt writes:
My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) There is a sobering story right along those lines at http://www.aopa.org/pilot/never_again/2008/na0801.html I find it interesting that the author says this VFR flight scared him more than any of his combat missions in Vietnam. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. Good. I wanted to make sure I'm not missing some risk or danger to following highways. From the article above I learned that things like wires and cables are a real risk if you're very close to the highway, but only a helicopter would be that low. |
Mxsmanic wrote in
: gatt writes: My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) There is a sobering story right along those lines at http://www.aopa.org/pilot/never_again/2008/na0801.html I find it interesting that the author says this VFR flight scared him more than any of his combat missions in Vietnam. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. Good. I wanted to make sure I'm not missing some risk or danger to following highways. From the article above I learned that things like wires and cables are a real risk if you're very close to the highway, but only a helicopter would be that low. Wow, hittign a virtual wire in a virtual airplane could really ruin your day if you were insane! Bertie |
Mxsmanic wrote:
From the article above I learned that things like wires and cables are a real risk if you're very close to the highway, but only a helicopter would be that low. Why would you say that? There are no differences in the allowed altitudes for fixed wing and rotary wing aircraft. And in a helo, just like in fixed wing, the more altitude the more options when there is a failure. |
Gig 601XL Builder writes:
Why would you say that? Helicopters can move more safely at very low altitudes because they are not obligated to move forward at any minimum speed. There are no differences in the allowed altitudes for fixed wing and rotary wing aircraft. There are big differences in flying over a road at 25 feet and 3 knots, and flying over a road at 25 feet and 95 knots. And in a helo, just like in fixed wing, the more altitude the more options when there is a failure. But at extremely low altitudes, the number of options required is reduced. If the engine fails in a helicopter at ten feet above the ground, it's not really a crisis. On a large flat area of ground, this can be true for an airplane, too, but airplanes have the added danger of rapid forward movement. |
Mxsmanic wrote:
Gig 601XL Builder writes: Why would you say that? Helicopters can move more safely at very low altitudes because they are not obligated to move forward at any minimum speed. We aren't talking about hovering over the highway we are talking about a VFR flight between two points. In that case one could expect both fixed and rotary wing aircraft to be traveling at a reasonable cruise speed. There are no differences in the allowed altitudes for fixed wing and rotary wing aircraft. There are big differences in flying over a road at 25 feet and 3 knots, and flying over a road at 25 feet and 95 knots. No not really. Both would be a violation in almost all cases. And in a helo, just like in fixed wing, the more altitude the more options when there is a failure. But at extremely low altitudes, the number of options required is reduced. If the engine fails in a helicopter at ten feet above the ground, it's not really a crisis. On a large flat area of ground, this can be true for an airplane, too, but airplanes have the added danger of rapid forward movement. Once again you show your ignorance. An engine failure in a helo hovering at 10 feet is just about the worst place that such a failure could happen. |
We aren't talking about hovering over the highway we are talking about a VFR flight between two points. In the article that gave rise to my comment, the pilot was indeed hovering over the highway, in a helicopter. Once again you show your ignorance. An engine failure in a helo hovering at 10 feet is just about the worst place that such a failure could happen. Explain. |
Mxsmanic wrote in
: Gig 601XL Builder writes: We aren't talking about hovering over the highway we are talking about a VFR flight between two points. In the article that gave rise to my comment, the pilot was indeed hovering over the highway, in a helicopter. That's not what you said fjukktard, you said forward speed doesn't matter. You were wrong. Bertie |
Mxsmanic wrote:
Gig 601XL Builder writes: We aren't talking about hovering over the highway we are talking about a VFR flight between two points. In the article that gave rise to my comment, the pilot was indeed hovering over the highway, in a helicopter. Just for the record here is your first post in this thread. Nowhere do you mention helicopters. Mxsmanic wrote: "Is it a bad idea to fly VFR at night and navigate by following highways? At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Are there hidden dangers in this? Do night VFR pilots ever/often navigate by following highways? What other forms of visual navigation are usable at night?" Once again you show your ignorance. An engine failure in a helo hovering at 10 feet is just about the worst place that such a failure could happen. Explain. It is high enough to kill you and too low to perform a proper auto-rotation. As forward speed increases the ability to perform a proper run-on landing increases. In a run-on landing you are pretty much treating the helo like a fixed wing. |
Arizona Highways magazine on soaring, flight | [email protected] | Soaring | 0 | December 20th 06 03:05 AM |
Night Flying. How many PPSEL pilots excersie night priveledges? | [email protected] | Piloting | 42 | December 16th 06 04:51 PM |
Night lights, night flights, OLC and records | Denis | Soaring | 19 | October 9th 06 11:51 PM |
Hood and sim work at night loggable as night time? | Ron Garret | Piloting | 12 | September 9th 06 02:15 AM |
FS2004 scenery which shows roads and highways? | John Doe | Simulators | 9 | March 25th 04 08:36 AM |
