Night VFR following highways
Old February 2nd 08, 02:16 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Night VFR following highways
gatt writes:
My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow
Roads " (or rivers)
There is a sobering story right along those lines at
http://www.aopa.org/pilot/never_again/2008/na0801.html
I find it interesting that the author says this VFR flight scared him more
than any of his combat missions in Vietnam.
Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch
through most of Oregon looks like somebody drew a straight line with a
pencil across the landscape. If you were flying from Portland (possible
Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow
the freeway the entire route.
You'd still use your VFR navigation aids and checkpoints to make sure know
how far you are enroute, and also to avoid controlled airspace, etc, but
having that road, railroad, river makes for a more-enjoyable flight.
Good. I wanted to make sure I'm not missing some risk or danger to following
highways. From the article above I learned that things like wires and cables
are a real risk if you're very close to the highway, but only a helicopter
would be that low.
Old February 2nd 08, 10:02 AM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
gatt writes:
Follow Roads " (or rivers)
more than any of his combat missions in Vietnam.
stretch through most of Oregon looks like somebody drew a straight
line with a pencil across the landscape. If you were flying from
Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day
or note you could follow the freeway the entire route.
know how far you are enroute, and also to avoid controlled airspace,
etc, but having that road, railroad, river makes for a more-enjoyable
flight.
following highways. From the article above I learned that things like
wires and cables are a real risk if you're very close to the highway,
but only a helicopter would be that low.
Wow, hittign a virtual wire in a virtual airplane could really ruin your
day if you were insane!
Bertie
Old February 4th 08, 02:44 PM posted to rec.aviation.student,rec.aviation.piloting
Gig 601XL Builder[_2_]
would be that low.
Why would you say that?
There are no differences in the allowed altitudes for fixed wing and
rotary wing aircraft. And in a helo, just like in fixed wing, the more
altitude the more options when there is a failure.
Old February 4th 08, 06:51 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Gig 601XL Builder writes:
Helicopters can move more safely at very low altitudes because they are not
obligated to move forward at any minimum speed.
There are big differences in flying over a road at 25 feet and 3 knots, and
flying over a road at 25 feet and 95 knots.
And in a helo, just like in fixed wing, the more altitude the
But at extremely low altitudes, the number of options required is reduced. If
the engine fails in a helicopter at ten feet above the ground, it's not really
a crisis. On a large flat area of ground, this can be true for an airplane,
too, but airplanes have the added danger of rapid forward movement.
Old February 4th 08, 07:27 PM posted to rec.aviation.student,rec.aviation.piloting
We aren't talking about hovering over the highway we are talking about a
VFR flight between two points. In that case one could expect both
fixed and rotary wing aircraft to be traveling at a reasonable cruise
speed.
No not really. Both would be a violation in almost all cases.
Once again you show your ignorance. An engine failure in a helo hovering
at 10 feet is just about the worst place that such a failure could happen.
Old February 5th 08, 01:13 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
In the article that gave rise to my comment, the pilot was indeed hovering
over the highway, in a helicopter.
Explain.
Old February 5th 08, 01:59 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
about a
hovering over the highway, in a helicopter.
That's not what you said fjukktard, you said forward speed doesn't matter.
You were wrong.
Bertie
Old February 5th 08, 03:16 PM posted to rec.aviation.student,rec.aviation.piloting
Just for the record here is your first post in this thread. Nowhere do
you mention helicopters.
Mxsmanic wrote:
"Is it a bad idea to fly VFR at night and navigate by following
highways? At
night outside large cities, there doesn't seem to be much else that's
visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it
should
work. Are there hidden dangers in this? Do night VFR pilots ever/often
navigate by following highways? What other forms of visual navigation are
usable at night?"
Explain.
It is high enough to kill you and too low to perform a proper
auto-rotation. As forward speed increases the ability to perform a
proper run-on landing increases. In a run-on landing you are pretty much
treating the helo like a fixed wing.
Old February 5th 08, 05:37 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
I said "in the article that gave rise to my comment," meaning an article to
which I provided a pointer. That article described the experience of a
helicopter pilot in marginal VFR at night.
auto-rotation.
Ten feet? I've seen helicopters fall to the ground from this height in videos
and while the helicopters may not survive if they don't remain upright, it
looks as though the occupants often can walk away from it. An engine failure
would be more gentle than a simple fall.
Old February 4th 08, 07:49 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
are not obligated to move forward at any minimum speed.
Wrong, fjukktard.
Bertie
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
