On Feb 3, 6:51 am, Bertie the Bunyip wrote:
FledgeIII wrote : On Feb 2, 7:41 pm, Bertie the Bunyip wrote: FledgeIII wrote innews:7921eb53-dcc7-4bce-984a- om: On Feb 2, 4:38 pm, Ron Wanttaja wrote: On Sat, 2 Feb 2008 09:44:56 +0000 (UTC), Bertie the Bunyip wrote: Ron Wanttaja wrote in : One would have thought the Fokker D-6 (essentially a biplane DR-1) would have quickly superseded it, then. But I suppose Fokker finally getting the Mercedes engine let him jump to the bigger D-7. I don't think the D-6 was quite as good as the Albatros, but it was probably better than the Triplane in most ways. I think the Triplane had it;s limited success as a sort of accident. Fokker was fond of just grabbing bits they had developed and grafting them to other bits and then lengthening this, shortening that until he came up with something that worked. I heard once that Tony Fokker (a Dutch national) was somehow under suspicion by the German government, and the military had refused to give him access to the newest engines...so he designed the best fighters he could around an old one until the Germans changed their minds. I always loved the japanese kite face on Voss's airplane. Back in the '60s, DC Comics had a series about a German WWI pilot called "Enemy Ace," which was based on Richtofen. But "Hans Von Hammer's" all-red triplane featured Voss' kite face, as shown on the current image on my Fly Baby's baggage door: http://www.bowersflybaby.com/pix/enemy%20ace.jpg One last bit of DR1 lore is that Manfred von Richtofen had four of them. He also preferred the French Gnome engine over the Oberursel whaich was basically a copy of the Gnome anyway. His airplanes were all equipped with Gnomes captured form downed airplanes. Well, uhhh, maybe. I'd heard that Oberursel sometimes put Gnome data plates on its engines, with an additional plate explaining it was a "captured" engine. Even in the middle of a war, they were worried about licensing laws.... Thanks for the info about von Richtofen's four DR-1s. Back as a kid building models, I noticed that none of the sources seemed to agree as to whether his machine was all-red or otherwise. Having more than one airplane would explain it.... Ron Wanttaja In one out of the way corner in the WWI section of the USAF Museum, there's a couple-inch square swatch of doped fabric in a frame, purported to be from the DR.I Richtofen died in. It's actually kind of a magenta color, but there's certain to be some fading involved... Yeah, it was ripped to shreds by souvenier hunters. Some if it is in Canada in a museum there including the seat. One of his tripes was preserved and displayed in a museum in germany, but it was destroyed in a bombing raid during the war. Bertie I also seem to recall reading someplace or other that one of - if not primary - motivations with tripes was to decrease span without sacrificing wing area - shortening the moments to increase roll and yaw rates. Yeah, that would be one of the reasons. Bipes are the same lots of wing area but you're affecting a smaller body of air. If you look at an airplane nose on and draw a circel around it which just touches the wingtips, you have a rough idea of the volume of air influenced by the airplane as it flies along. A bipe or tripe will affect a smaller area. It's morre compicated than that, of course, but it's a good ROT Kind of squares with stories of how guys like Voss flew the thing - bat**** crazy; flat turns, snap rolls, you name it. Yeah I read a report on a modern one years ago and apparently it's yaw behaviour is very strange indeed. He said it was nearly impossible to tell if you were skidding as the thing would just fly along with the wings level and the ailerons neutral and going mare sideways than straight ahead. You had to be on the rudder all the time. Vigorous application of the rudder would initiate mad flat turns of ridiculously small radius,whihc apparently made the thing a very good gun platform. It must have been a tremedous advantage in surprise terms alone. Another thing I recall reading was that it offered some advantages in visibility - high aspect ratio (narrow chord)/low stagger wings, the middle wing aligned right on line of sight where it obscured the least lateral vision. Then again, I could be all wt on that... ![]() As Dudley said, I believe you're completely blind on landing, but all the bipes of tha era had vis issues. There were some weird experiments n that direction as well. The DH5 used negative stagger and had the cockpit in front of the wings, for instance. The Sopwith Dolphin had a weird aproach that's hard to describe. Bertie Yeah I read a report on a modern one years ago and apparently it's yaw behaviour is very strange indeed. He said it was nearly impossible to tell if you were skidding as the thing would just fly along with the wings level and the ailerons neutral and going mare sideways than straight ahead. You had to be on the rudder all the time. Vigorous application of the rudder would initiate mad flat turns of ridiculously small radius,whihc apparently made the thing a very good gun platform. It must have been a tremedous advantage in surprise terms alone. Wouldn't be surprised if that's the reason pictures from the time - and later on in movies like The Blue Max show DR.Is with streamers trailing from the interplanes; most likely as big 'ole honkin' yaw strings... Good point on the early D.VII fuselage; was thinking about that myself. IIRC, the prototype had the same small "comma shaped" rudder stab as the DR.I; they added the forward strake/fin when they lengthened the fuselage. |
Triplane PWS Po-2 | fox | Aviation Photos | 0 | August 30th 07 08:08 AM |
Dr.1 triplane | Glenn[_2_] | Aviation Photos | 0 | June 16th 07 12:52 PM |
Dr1 Triplane | Glenn[_2_] | Aviation Photos | 1 | June 10th 07 04:07 AM |
