Boeing Awarded Contract For Next-Generation Harpoon Block III Missile
Old February 3rd 08, 10:15 PM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
Default Boeing Awarded Contract For Next-Generation Harpoon Block III Missile
"Paul J. Adam" wrote:
:The requirement to engage over the horizon assumes that OTH shots are
:likely and permissible, which in the current state of affairs is highly
:arguable (and Harpoon is pretty good for those should there be a
:requirement).
We will not always be fighting today's war, Paul. Planning your
capabilities based on what you're doing today virtually guarantees
that you will be caught short tomorrow.
You have never lived until you have almost died.
Life has a special meaning that the protected
will never know.
  #42
Old February 3rd 08, 10:36 PM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
Peter Skelton wrote:
:On Sun, 03 Feb 2008 13:43:58 -0700, Fred J. McCall
:Peter Skelton wrote:
::On Sun, 03 Feb 2008 08:53:26 -0700, Fred J. McCall
::Peter Skelton wrote:
:::On Sat, 02 Feb 2008 19:06:22 -0700, Fred J. McCall
:::"dott.Piergiorgio" wrote:
::::Fred J. McCall ha scritto:
:::: Why? What does it get you? The missile is already 20x faster than
:::: what you're shooting it at.
:::: Capability isn't free. If you want a supersonic anti-ship missile, it
:::: has to be bigger (which means you can carry fewer of them), fly higher
:::: (to escape reflections of its own shockwave from the surface), etc.
::::As I understand, very high speed in ASuW missiles is conceived as
::::counter-measure against CIWS systems, on the basis of reducing the
::::available reaction time.
:::I know it's viewed that way, but does it really buy you anything? You
:::pick it up farther away (because it has to fly higher and is larger)
:::and you have many fewer missiles to use to try to overload a defensive
:::sector (again, because the missiles must be much larger).
:::And, of course, a larger, hotter missile is also easier to hit once
:::you detect it...
:::Aren't the small, modified AA missles supersonic, small and about
:::as long-ranged as harpoon? They've a much smaller punch -
:::nothing's free, as you say, but they'd be likely to hit against
:::current defenses.
::I'm not sure what missiles you're talking about.
::The standard family for certain, I'm not sure how much other kit
::has been upgraded.
:I don't believe they are nearly as long-ranged as Harpoon when they
:are used in the anti-ship mode. One of the things you give up for
:supersonic speed is range (you burn the fuel grain much faster) unless
:you make them very, very large.
:They are longer ranged in anti-ship mode than in anti-air - it
:has to be that way, the height it has in AA mode at maximum range
:is available as energy to get out farther at the surface. SM2 ER
:should be good to 90 sea miles.
No, it doesn't have to be that way at all. Air resistance matters.
What altitude the rocket nozzle is optimized for matters. Flight
profile matters.
:That doesn't mean targeting and sensors work that way, the world
:being curved and all.
I'm not sure that these are usefully smaller than harpoon - the
:diameter of both is 13.5")
They're not. In fact they're pretty much the same size and weight.
The Standard Missile motor burns much hotter. Flight profile is very
different. Standard will launch from a Mk-41 VLS while Harpoon will
not.
"The reasonable man adapts himself to the world; the unreasonable
man persists in trying to adapt the world to himself. Therefore,
all progress depends on the unreasonable man."
--George Bernard Shaw
  #43
Old February 3rd 08, 10:39 PM posted to sci.military.naval,rec.aviation.military.naval
Dean A. Markley
Default Boeing Awarded Contract For Next-Generation Harpoon Block IIIMissile
snipped
(I'm not sure that these are usefully smaller than harpoon - the
Peter Skelton
A quick search reveals the following:
Harpoon weight of 1145 lbs Max Speed = 530mph
SM2 weight of 2980 lbs(don't know if this includes booster) Max Speed =
1900mph
Now the Harpoon carries a much larger warhead but the SM2 is heavier and
impacts at a much higher speed. Is it reasonable to make a SWAG that a
Standard SM2 will inflict as much or more damage?
After all, speed kills....
Dean
  #44
Old February 3rd 08, 10:50 PM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
:snipped
: They are longer ranged in anti-ship mode than in anti-air - it
: has to be that way, the height it has in AA mode at maximum range
: is available as energy to get out farther at the surface. SM2 ER
: should be good to 90 sea miles.
: That doesn't mean targeting and sensors work that way, the world
: being curved and all.
: (I'm not sure that these are usefully smaller than harpoon - the
: diameter of both is 13.5")
: Peter Skelton
:A quick search reveals the following:
Should have searched a bit slower. Let me correct:
:Harpoon weight of 1145 lbs Max Speed = 530mph
That's the weight for the air-launch Harpoon. If you launch it from a
ship it weighs almost 1500 pounds.
:SM2 weight of 2980 lbs(don't know if this includes booster) Max Speed =
:1900mph
That's the weight for the ER version. It's over 26 feet long and I
don't believe we currently have any ships that fire it. The MR
version of SM-2 weighs around 1400 pounds.
Oh, and that 1900 MPH is at altitude. It's going to be slower down in
denser air.
:Now the Harpoon carries a much larger warhead but the SM2 is heavier and
:impacts at a much higher speed. Is it reasonable to make a SWAG that a
:Standard SM2 will inflict as much or more damage?
:After all, speed kills....
By the time they reach the target, Harpoon is probably heavier
(because of the heavier warhead). A lot of that weight in the
Standard round is fuel.
Speed isn't what kills. That's why we put warheads on the things.
"Millions for defense, but not one cent for tribute."
-- Charles Pinckney
  #45
Old February 4th 08, 03:17 AM posted to sci.military.naval,rec.aviation.military.naval
Peter Skelton
On Sun, 03 Feb 2008 15:36:50 -0700, Fred J. McCall
:::you detect it...
profile matters.
Straight down is always achievable
Peter Skelton
  #46
Old February 4th 08, 04:23 AM posted to sci.military.naval,rec.aviation.military.naval
Andrew Swallow[_2_]
[snip]
Over the horizon targeting could be performed by an aircraft,
satellite or small boat.
Andrew Swallow
  #47
Old February 4th 08, 05:10 AM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
:On Sun, 03 Feb 2008 15:36:50 -0700, Fred J. McCall
::On Sun, 03 Feb 2008 13:43:58 -0700, Fred J. McCall
:::On Sun, 03 Feb 2008 08:53:26 -0700, Fred J. McCall
:::Peter Skelton wrote:
::::On Sat, 02 Feb 2008 19:06:22 -0700, Fred J. McCall
::::"dott.Piergiorgio" wrote:
:::::Fred J. McCall ha scritto:
::::: Why? What does it get you? The missile is already 20x faster than
::::: what you're shooting it at.
::::: Capability isn't free. If you want a supersonic anti-ship missile, it
::::: has to be bigger (which means you can carry fewer of them), fly higher
::::: (to escape reflections of its own shockwave from the surface), etc.
:::::As I understand, very high speed in ASuW missiles is conceived as
:::::counter-measure against CIWS systems, on the basis of reducing the
:::::available reaction time.
::::I know it's viewed that way, but does it really buy you anything? You
::::pick it up farther away (because it has to fly higher and is larger)
::::and you have many fewer missiles to use to try to overload a defensive
::::sector (again, because the missiles must be much larger).
::::And, of course, a larger, hotter missile is also easier to hit once
::::you detect it...
::::Aren't the small, modified AA missles supersonic, small and about
::::as long-ranged as harpoon? They've a much smaller punch -
::::nothing's free, as you say, but they'd be likely to hit against
::::current defenses.
:::I'm not sure what missiles you're talking about.
:::The standard family for certain, I'm not sure how much other kit
:::has been upgraded.
::I don't believe they are nearly as long-ranged as Harpoon when they
::are used in the anti-ship mode. One of the things you give up for
::supersonic speed is range (you burn the fuel grain much faster) unless
::you make them very, very large.
::They are longer ranged in anti-ship mode than in anti-air - it
::has to be that way, the height it has in AA mode at maximum range
::is available as energy to get out farther at the surface. SM2 ER
::should be good to 90 sea miles.
:No, it doesn't have to be that way at all. Air resistance matters.
:What altitude the rocket nozzle is optimized for matters. Flight
:profile matters.
:Straight down is always achievable
But hitting something that way isn't.
"Some people get lost in thought because it's such unfamiliar
territory."
--G. Behn
  #48
Old February 4th 08, 05:47 AM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
:Over the horizon targeting could be performed by an aircraft,
:satellite or small boat.
Not without radical changes to the missile. And if you're going to do
that, why not just modify it enough so that OTH targeting isn't
required?
  #49
Old February 4th 08, 07:54 AM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
Paul J. Adam ha scritto:
In message , Peter Skelton
writes
has been upgraded.
What's to upgrade? Inside horizon distance, a lot of SAMs have
demonstrable surface-to-surface modes. Sea Slug did, and Sea Dart still
does. (One excuse why the 42s don't have a SSM fit).
And the seaslug got also an impromptu land-attack mode, full descripted
in Inskip's "Ordeal by Exocet".
Personally I think that the virtues of electronics up until early 90s is
their flexibility and adaptability to procedures & modification not
envisioned by manufacturers. If recent batches of Military hardware are
hardware& software locked like the rest of current electronics, (for
example, someone can modify or make A&A on LCD TV set ?) I guess that
many troubles lies not far ahead....
Best regards from Italy,
Dott. Piergiorgio.
  #50
Old February 4th 08, 06:36 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
Jack Linthicum ha scritto:
6 march of what year ? AFAICT the last Vandal (former Talon missiles)
was expended sometime in the 2004-5 timeframe...
Dott. Piergiorgio.
It's a 2002 article from Sea Power
http://findarticles.com/p/articles/m...05/ai_n9021027
OK thanks.
Dott. Piergiorgio.
AeroVironment Awarded Contract for Development of Global Observer Stratospheric Unmanned Aircraft System Larry Dighera Piloting 4 May 21st 09 01:57 AM
ITT awarded ADS-B contract Doug Vetter Piloting 7 August 31st 07 07:32 PM
Boeing $241.8 million contract ballistic missile-hunting Airborne Laser Larry Dighera Military Aviation 1 May 29th 04 12:05 PM
Next Generation Aircraft Carrier Contract Awarded Otis Willie Naval Aviation 6 May 23rd 04 02:53 PM
The U.S. Air Force awarded BOEING CO. a $188.3 million new small-diameter precision-guided bomb contract Larry Dighera Military Aviation 3 October 28th 03 12:07 PM
