Night VFR following highways
Old February 5th 08, 01:13 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Night VFR following highways
Gig 601XL Builder writes:
We aren't talking about hovering over the highway we are talking about a
VFR flight between two points.
In the article that gave rise to my comment, the pilot was indeed hovering
over the highway, in a helicopter.
Once again you show your ignorance. An engine failure in a helo hovering
at 10 feet is just about the worst place that such a failure could happen.
Explain.
Old February 5th 08, 01:59 AM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
about a
hovering over the highway, in a helicopter.
That's not what you said fjukktard, you said forward speed doesn't matter.
You were wrong.
Bertie
Old February 5th 08, 03:16 PM posted to rec.aviation.student,rec.aviation.piloting
Gig 601XL Builder[_2_]
Just for the record here is your first post in this thread. Nowhere do
you mention helicopters.
Mxsmanic wrote:
"Is it a bad idea to fly VFR at night and navigate by following
highways? At
night outside large cities, there doesn't seem to be much else that's
visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it
should
work. Are there hidden dangers in this? Do night VFR pilots ever/often
navigate by following highways? What other forms of visual navigation are
usable at night?"
Explain.
It is high enough to kill you and too low to perform a proper
auto-rotation. As forward speed increases the ability to perform a
proper run-on landing increases. In a run-on landing you are pretty much
treating the helo like a fixed wing.
Old February 5th 08, 05:37 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
I said "in the article that gave rise to my comment," meaning an article to
which I provided a pointer. That article described the experience of a
helicopter pilot in marginal VFR at night.
auto-rotation.
Ten feet? I've seen helicopters fall to the ground from this height in videos
and while the helicopters may not survive if they don't remain upright, it
looks as though the occupants often can walk away from it. An engine failure
would be more gentle than a simple fall.
Old February 5th 08, 05:52 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
do you mention helicopters.
article to which I provided a pointer. That article described the
experience of a helicopter pilot in marginal VFR at night.
auto-rotation.
in videos and while the helicopters may not survive if they don't
remain upright, it looks as though the occupants often can walk away
from it. An engine failure would be more gentle than a simple fall.
Nope.
Bertie
Old February 5th 08, 07:19 PM posted to rec.aviation.student,rec.aviation.piloting
And we were supposed to know that, how?
auto-rotation.
Depends on the helo and more importantly how it lands. They are designed
to handle some amount of hard landing but a hard landing can easily turn
into an overturned craft and then all bets are off.
Anything short of 400 feet and auto-rotation probably isn't going to be
successful.
Old February 5th 08, 11:40 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
By following the thread, and actually reading the article.
Old February 6th 08, 06:05 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
Yeh. like any of your posts are worth following
Bertie
Old February 6th 08, 02:21 PM posted to rec.aviation.student,rec.aviation.piloting
Damn, you are an idiot.
I quoted your original post and you admitted that you hadn't mentioned
helos in it.
Old February 6th 08, 05:23 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
helos in it.
So? I explained where the reference came from.
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
