![]() wrote in message ... On Feb 5, 9:58 am, Jack Linthicum wrote: On Feb 5, 9:25 am, " wrote: On Feb 5, 9:12 am, Jack Linthicum wrote: On Feb 5, 9:10 am, Typhoon502 wrote: On Feb 5, 9:02 am, " wrote: On Feb 5, 6:07 am, "Mr.Smartypants" wrote: No one has really shot at them yet. They'll be sitting ducks when in transition mode. Moreso than a hovering helicopter? That's helicopter mode. Mr. Smartypants thinks that somehow the transition state, when the nacelles are neither horizontal nor vertical, is something scary. The fact is, during transition, the aircraft retains enough forward velocity to make the wings generate useful lift, and if the pilot needs to lay on speed, those nacelles can drop and those big blades can get that bird moving in a hurry. Also, V-22 structures have been shot plenty of times in the test phase. Its ability to take hits is not some nebulous unknown quantity. Cite- http://www.navair.navy.mil/V22/index....detail&id=170 This paragraph "But what if the aircraft is hit by enemy fire? How vulnerable is it? The MV-22 has undergone an extensive live fire test and evaluation (LFT&E) program consisting of no less than 60 test events and totaling more than 592 ballistic test firings (more than any aircraft in Department of Defense history). All flight control actuators were proven to be resistant to light antiaircraft artillery armor piercing incendiary (API) at 90 percent muzzle velocity. During tests of the wing structure, multiple 23mm (API and high-explosive incendiary (HEI)) shots failed to compromise the load carrying integrity of the wing. Portions of the structure were actually determined to be invulnerable to all API and HEI projectiles up to and including 23mm. Overall the LFT&E effort determined that the probability of an aircraft kill (given a hit) was significantly less than that of existing helicopters." reads just like the discounted first few. I would like to see a nice unclassified test and evaluation report, even a document number, that tells me this has elements of the truth in it and is not some Henderson Hall flack making up war stories. I don't know....helicopters are not known for their survivability, so the standard isn't necessarilly all that high. The Osprey can go faster, higher, and longer with a greater payload. If it's just as serviceable and survivable as a helicopter, it's a step forward. ------------------------- I thought the major issue was their nasty tendency to fall out of the sky if they fly too close together. -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. |
On Feb 5, 10:17*am, "William Black"
wrote: wrote in message ... On Feb 5, 9:58 am, Jack Linthicum wrote: On Feb 5, 9:25 am, " wrote: On Feb 5, 9:12 am, Jack Linthicum wrote: On Feb 5, 9:10 am, Typhoon502 wrote: On Feb 5, 9:02 am, " wrote: On Feb 5, 6:07 am, "Mr.Smartypants" wrote: No one has really shot at them yet. They'll be sitting ducks when in transition mode. Moreso than a hovering helicopter? That's helicopter mode. Mr. Smartypants thinks that somehow the transition state, when the nacelles are neither horizontal nor vertical, is something scary. The fact is, during transition, the aircraft retains enough forward velocity to make the wings generate useful lift, and if the pilot needs to lay on speed, those nacelles can drop and those big blades can get that bird moving in a hurry. Also, V-22 structures have been shot plenty of times in the test phase. Its ability to take hits is not some nebulous unknown quantity. Cite- http://www.navair.navy.mil/V22/index....detail&id=170 This paragraph "But what if the aircraft is hit by enemy fire? How vulnerable is it? The MV-22 has undergone an extensive live fire test and evaluation (LFT&E) program consisting of no less than 60 test events and totaling more than 592 ballistic test firings (more than any aircraft in Department of Defense history). All flight control actuators were proven to be resistant to light antiaircraft artillery armor piercing incendiary (API) at 90 percent muzzle velocity. During tests of the wing structure, multiple 23mm (API and high-explosive incendiary (HEI)) shots failed to compromise the load carrying integrity of the wing. Portions of the structure were actually determined to be invulnerable to all API and HEI projectiles up to and including 23mm. Overall the LFT&E effort determined that the probability of an aircraft kill (given a hit) was significantly less than that of existing helicopters." reads just like the discounted first few. I would like to see a nice unclassified test and evaluation report, even a document number, that tells me this has elements of the truth in it and is not some Henderson Hall flack making up war stories. * *I don't know....helicopters are not known for their survivability, so the standard isn't necessarilly all that high. The Osprey can go faster, higher, and longer with a greater payload. If it's just as serviceable and survivable as a helicopter, it's a step forward. ------------------------- I thought the major issue was their nasty tendency to fall out of the sky if they fly too close together. -- William Black That seems to be a failure of darn near all aircraft. |
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" | Mike[_7_] | Naval Aviation | 50 | November 30th 07 05:25 AM |
Citizen stuns congresswoman: "Why should we divide Iraq for israel?" | [email protected] | Naval Aviation | 0 | October 24th 07 10:12 AM |
"Afghan war has lessons for U.S. pilots in Iraq" | Mike[_7_] | Naval Aviation | 4 | February 23rd 07 06:07 PM |
SQUADRON TAXI - "IMG_1276.JPG" 172.4 KBytes | Peter Hucker | Aviation Photos | 0 | November 11th 06 06:54 PM |
Marine Corps Now Authorized To Use "Involuntary Recall" To Force Thousands Back To Iraq (for Israel, of course!) - see comments on page 1 of following URL: | dontcowerfromthetruth | Naval Aviation | 0 | August 23rd 06 09:23 AM |
