Oh, he's good...
Old February 10th 08, 03:52 PM posted to rec.aviation.piloting
William Hung[_2_]
Default Oh, he's good...
http://youtube.com/watch?v=FCWFMJaBLl0&feature=related
While "researching" stol aircrafts, I came across this.
Wil
Old February 10th 08, 04:11 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
William Hung wrote in news:b91186d4-fa32-498d-ac70-
Wil
This is actualy pretty easy to do in a lot of taildraggers, especially a
cub. Just a bit of brake against power with some forward stick. You can
taxi around all day like this.
Bertie
Old February 10th 08, 04:16 PM posted to rec.aviation.piloting
William Hung[_2_]
Wil
Bertie
Keeping the tail off the ground? I suppose it is even easier in a
tricycle geared ones. lol
Inches from a prop-strike, seconds from a prop-strike. I wonder how
many engines he had to have torn down before he got that good.
Wil
Old February 10th 08, 04:23 PM posted to rec.aviation.piloting
William Hung wrote in news:d5ad9f37-e01f-4e0b-9aad-
ac70-
Wil
especially a
can
Bertie
True!
in some of those I've taxied with the nosewheel off the ground, though!
Like I said, it's easy. Anyone could do it in a cub with only a little
practice. If it starts to go too far you release the brakes and it sits
down. It's as simple as that. It's lots lots lots easier than it looks.
One problem is that you have a good bit of power on, especially at very
low speeds and your prop is down near the ground where it can pick up
grit.
Bertie
Old February 10th 08, 04:50 PM posted to rec.aviation.piloting
William Hung[_2_]
ac70-
Wil
especially a
can
Bertie
True!
Inches from a prop-strike, seconds from a prop-strike. *I wonder how
Like I said, it's easy. *Anyone could do it in a cub with only a little
grit.
Bertie- Hide quoted text -
- Show quoted text -
My pocket's not that deep Bertie, I'll have to take your word for it.
Wil
Old February 10th 08, 06:01 PM posted to rec.aviation.piloting
William Hung wrote in news:fd5164ed-0d1d-4bc7-98f0-
9aad-
ac70-
Wil
especially a
You
can
Bertie
True!
though!
how
little
sits
looks.
very
grit.
Not many things cheaper to fly than a cub!
I had a job towing banners once and learned to do it there. The boss
probably would not have appreciated it as it would have been a bit hard
on the brakes.
Bertie
Old February 10th 08, 06:10 PM posted to rec.aviation.piloting
Wil
Finest kind!
I bet the guys who rent the tail dragger down the ramp from my club
would have a brain blowout if you taxied in like that, though.
Prolly never rent to you again
Old February 10th 08, 10:02 PM posted to rec.aviation.piloting
ac70-
Wil
especially a
can
Bertie
True!
grit.
Bertie
I learned to stop the 185 really short doing just this. And
taxied the old Auster like that. Not as hard as it looks, but you sure
gotta be careful. My Jodel, on the other hand, is really finely
balanced, rather light in the tail, and I've never had the nerve to do
it. Maybe this spring:-)
The taildragger's CG is usually 15° behind the main axles.
Picking up the tail of a taildragger, you can hoist it over your head
so that it's pointing down at 15° or so, and it'll balance there. Prop
horizontal so it doesn't get stabbed into the pavement. With the
brakes on and engine run up, it's easy enough to keep the tail from
rising to that level.
Dan
Old February 10th 08, 11:33 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Wil
Bertie
Wil
Bertie's right. It's not hard at all. Used to do it myself in a comedy
act we threw together based on my good friend Dick Schramms flying
professor routine. We used a J3 Cub. The only thing you really had to
worry about was getting oil on your shoes. I always wore tennis shoes
when doing this act. The J3's brakes were heel brakes and were located
next to the rudder T's slightly inside. If your foot slipped off the
brakes at the wrong time...well..let's just say that writing a check to
Sensinich would have spoiled the day for us :-))
Dudley Henriques
Good By Roger Long Piloting 16 March 9th 06 02:28 AM
Good-bye, My Good Friend Capt.Doug Home Built 2 August 12th 05 02:47 AM
Good Good America Chris Mark Military Aviation 4 July 9th 04 05:25 PM
good-bye franck jeamourra Owning 0 December 2nd 03 07:51 AM
