Why airplanes fly
Old February 11th 08, 12:53 AM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Default Why airplanes fly
Michael Ash wrote in
In rec.aviation.student Dudley Henriques wrote:
Michael Ash wrote:
In rec.aviation.student Bertie the Bunyip wrote:
Yes. I've trid it and the home sim feedback systems are a joke.
Even sophisticated sims aren't great this way and I still can't see
even the most sophisticated sims being anything more than an aid in
teaching procedures.
Seems like you ought to be able to get a fairly decent setup by
using bungees to center the stick and having some motors on the
bungees. Move them around to change the center if needed, tighten
them to provide more recentering force at high speed. Anyone know
how the real force feedback systems work and why my idea doesn't?
Wouldn't be worth the trouble. No matter what you do with force
feedback, unless you can come up with a way to duplicate the effect
of dynamic pressure on control surfaces based on a varying airspeed
and air density table, and for a specific aircraft to boot....you
can't duplicate actual control pressures for a desk top simulator.
I imagine you could do a fairly decent job. A sim such as X-Plane has
much of the data needed to come up with the right numbers. But then
again, I don't know whether this is "fairly decent" as in something
which just deceives you, or as in something which is actually
worthwhile. In any case it's somewhat academic, since if the software
doesn't support it then there's no point in having the hardware, and
if there's no hardware the software won't support it....
If even the big iron sims don't do a good job, it should be a good
indication that this problem is harder than it looks from the outside.
Well, the smoothest pilots i know can't fly a "good" sim. The mechanical
ones can..
Says it all, really.
Bertie
Old February 11th 08, 04:20 AM posted to rec.aviation.piloting, rec.aviation.student
ones can..
Bertie- Hide quoted text -
- Show quoted text -
It's down to rainy day or otherwise IFR for me. Only time I do it. And
I get bored really fast -- no matter how many add ons I jam in it.
Doesn't hold a candle to the real thing.
Old February 11th 08, 01:48 PM posted to rec.aviation.piloting,rec.aviation.student
wrote in
Michael Ash wrote
et.com:
see even the most sophisticated sims being anything more than an
aid in teaching procedures.
effect of dynamic pressure on control surfaces based on a varying
airspeed and air density table, and for a specific aircraft to
boot....you can't duplicate actual control pressures for a desk
top simulator.
has much of the data needed to come up with the right numbers. But
then again, I don't know whether this is "fairly decent" as in
something which just deceives you, or as in something which is
actually worthwhile. In any case it's somewhat academic, since if
the software doesn't support it then there's no point in having the
hardware, and if there's no hardware the software won't support
it....
outside.
mechanical ones can..
Yeah, I have a couple of them lying around and I never use them. Once
you've flown under a couple of bridges they are a complete bore.
Exactly.
Bertie
New and Used Airplanes [email protected] Products 0 May 29th 07 05:02 PM
How many GA airplanes... john smith Piloting 2 May 10th 06 05:19 PM
Q On NYC Airplanes John A. Weeks III General Aviation 3 March 16th 06 12:35 PM
AIRPLANES! W P Dixon Home Built 10 October 7th 04 11:28 AM
E-bay airplanes Paul Folbrecht Owning 11 March 4th 04 12:00 AM
