CB SWR meter on 122Mhz?
Old February 13th 08, 04:37 PM posted to rec.aviation.homebuilt
Default CB SWR meter on 122Mhz?
Tom,
I concur with Jay. You need a unit designed for the frequency being tested.
MFJ Enterprises has as series of suitable VHF SWR/Watt Meters starting at
about $40.
http://www.mfjenterprises.com/Caterg...45fc51f462651f
or
http://tinyurl.com/yo26k6
I personally use the SWR in my old RST-721 test set.
W7ADK
http://www.soaridaho.com/
"Jay Maynard" wrote in message
On 2008-02-13, noman wrote:
How well do you think a CB SWR meter will work for testing the antenna
installation in an airplane?
Not worth a damn. The sensing circuitry is almost certainly not going to
work
properly at VHF. A meter designed for the 2-meter ham radio band would
work,
though.
What are you trying to find out? Unless something is corroded or broken,
whatever problem you have is probably not your antenna.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old February 13th 08, 04:52 PM posted to rec.aviation.homebuilt
RST Engineering
W7ADK
Old February 13th 08, 05:28 PM posted to rec.aviation.homebuilt
Jim,
The RST-721 is a great little unit. In addition to tuning the antennas on
the local experimental sailplanes, I use it for my 2 meter equipment.
I didn't build one of your transceivers. I inherited the unit from a friend
who retired from soaring in his 80s.
(http://www.soaridaho.com/photogaller...k_is_Ready.jpg)
I wish aircraft tranceiver kits were still available. I enjoy building
electronics as much as working on my sailplane.
(http://www.soaridaho.com/Schreder/HP-14/N990/N990.html) I built all my
amateur radion HF equipment. (Heathkit SB-310, SB-200, SB-101 and SB640)
These old tube-based units are still running great.
W7ADK
"RST Engineering" wrote in message
W7ADK
For sale: DG-600 17-meter and 15-meter wingtips Lars Peder Hansen Soaring 0 January 21st 07 06:18 PM
FS: G Meter nobody Aviation Marketplace 0 August 6th 05 06:58 PM
G meter Paul Anton Home Built 0 June 4th 05 06:45 PM
SWR meter Paul Lee Home Built 3 May 31st 04 02:47 PM
G-meter G.R. Patterson III Piloting 2 February 29th 04 03:13 PM
