Thielert (Diesel Engines)
Old February 14th 08, 05:24 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
Default Thielert (Diesel Engines)
David Lesher wrote in news:fp1t8e$8vr$4
@reader2.panix.com:
Bertie the Bunyip writes:
There's nothing made up about "No sparks, no power" I wouldn't buy one
because of this. My club was looking at one ofr a Cherokee and decided
against it because of the lack of limp home capability.
What kind of sparks does a Diesel need?
This ine has a FADEC. No electricity and you have a big weight up front.
Worse, in the twin star installation, both engines are tied to an
electrical system that can punch out both at the same time. in this case,
when the gear was retracted...
http://goliath.ecnext.com/coms2/gi_0...FADEC-0-a.html
Nice eh?
Bertie
Old February 14th 08, 05:42 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
On Thu, 14 Feb 2008 17:24:52 +0000 (UTC), Bertie the Bunyip
Nice eh?
To be fair, there was an immediate AD requiring a backup battery
systtem to power the FADECs after that event. I'm surprised it wasn't
required for certification in the first place since it appears to me
that it was a forseeable failure mode, but still.
Old February 14th 08, 05:46 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark wrote in
one because of this. My club was looking at one ofr a Cherokee and
decided against it because of the lack of limp home capability.
front.
case, when the gear was retracted...
Nice eh?
There's lots of ways you can lose all electrics. Corrosion, lightning,
poor maintenance...
A manual reversion mode or at least a fail safe to a constant power
setting weould be a major improvement and the ony thing that would make
the engine a viable modern airplane engine in my view. I've flown single
ignition airplanes, but there is a world of difference between flying an
antique with low approahc speeds and a modern(ish) lightplane.
Bertie
Old February 14th 08, 06:34 PM posted to rec.aviation.owning,rec.aviation.piloting
WingFlaps
front.
Nice eh?
systtem to power the FADECs after that event. *I'm surprised it wasn't
poor maintenance...
I agree. Isn't that a problem for electrical ignition systems? Limp
home should be excellent in a diesel...
Cheers
Old February 14th 08, 06:46 PM posted to rec.aviation.owning,rec.aviation.piloting
WingFlaps wrote in
Peter Clark wrote
innews:qav8r3
buy one because of this. My club was looking at one ofr a
Cherokee and decided against it because of the lack of limp home
capability.
front.
http://goliath.ecnext.com/coms2/gi_0...ate-1-FADEC-0-
a.htm
l
Nice eh?
wasn't
me that it was a forseeable failure mode, but still.
lightning, poor maintenance...
Well, there are two mostly! Completely independent as well. Not the case
here. You can add backup batteries and what not, but they're still
connected to the same fadec.
Limp
Should be, but in this engine it is non-existent. It's not diesels in
general I'm knocking. It's this engine only..
Bertie
Old February 14th 08, 11:25 PM posted to rec.aviation.owning
Morgans[_2_]
"Bertie the Bunyip" wrote x
Exactly.
Limp home, or better, should be a no brainer for a diesel.
The choice not to have that feature on this particular engine is, no doubt,
an economic decision. They felt that the need for it, determined by the
risk of failure, is not a large enough factor to necessitate the extra cost
of including this feature.
Perhaps they will survey possible buyers, or determine by some other
vehicle, that this is an important reason for potential customers to not buy
their package. Doubtful, but one can hope...
As to losing the electrical supply to the fadec, only a poor design and
implementation could result in a totally bulletproof and totally reliable
system. The backup circuit and battery should supply only the fadec, and
fuel pump; only the absolute minimum necessary systems needed to keep the
fan turning. A self test should check the ability of the backup circuit to
run these systems upon every start, and also if something changes during
flight that would prevent the backup from functioning.
Is that how it is now, with the only widely used diesel? No. It should not
be difficult or overly costly to build a system to function like that. I
guess we will have to wait for the experimental crowd to design such a
system. g
Jim in NC
Old February 15th 08, 10:09 AM posted to rec.aviation.owning
Thomas Borchert
Morgans,
No, no and no again. This is not the diesel Americans are used to from their
boats and trucks. Modern car diesel engines require electronic control. Google
common rail.
Thomas Borchert (EDDH)
Old February 15th 08, 10:09 AM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Bertie,
Not the case
There are two FADECs. Get yourself some factual information before
spouting your theories!
Old February 15th 08, 01:36 PM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert wrote in
Bertie,
Not the case
It;'s not a theory and you know it.Both fadecs electric, are they?
Bertie
Old February 14th 08, 06:44 PM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_1_]
front.
Nice eh?
poor maintenance...
Bertie
This aircraft had 2 working alternators when the volts dropped and the
FADECs(4) quit. Had each engine shed the electrical load quick enough, this
would not have happened. Apparently it takes less than a 1/4 second of low
volts to "reboot".
Al G
Thielert (Diesel Engines) Charles Talleyrand Piloting 108 February 19th 08 04:59 PM
diesel 160-200HP engines geo Home Built 27 April 2nd 04 04:27 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
