WingFlaps wrote in
: On Feb 15, 9:32*am, Bertie the Bunyip wrote: WingFlaps wrote in news:043b8c97-e1d9-463a-9d5f- : On Feb 15, 12:31*am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. *Only true as long as you don't bust airspace or aircraft operating limitations... Well, neither one has much to do with a vertical speed limit. A dive which goes over Vne? Well, yes, flight testing for instance. VNE is 10% below a tested dive speed. Alos, as I posted before, some airplanes had an emergency dive speed. Vd. I'd have to look it up to see, though. In any case, it's not a legal limit, it;'s a design limitation. Bertie |
On Feb 16, 2:08 am, Bertie the Bunyip wrote:
Well, yes, flight testing for instance. VNE is 10% below a tested dive speed. Alos, as I posted before, some airplanes had an emergency dive speed. Vd. I'd have to look it up to see, though. In any case, it's not a legal limit, it;'s a design limitation. I know one or two jump pilots who drop their load and are back on the deck picking up the next load before the first have all landed |
george wrote in
: On Feb 16, 2:08 am, Bertie the Bunyip wrote: Well, yes, flight testing for instance. VNE is 10% below a tested dive speed. Alos, as I posted before, some airplanes had an emergency dive speed. Vd. I'd have to look it up to see, though. In any case, it's not a legal limit, it;'s a design limitation. I know one or two jump pilots who drop their load and are back on the deck picking up the next load before the first have all landed I doubt they're going past VNE, though. No need, really. I wouldn't want to be footing their engine bills, though! Bertie |
On Feb 16, 2:08*am, Bertie the Bunyip wrote:
WingFlaps wrote : On Feb 15, 9:32*am, Bertie the Bunyip wrote: WingFlaps wrote in news:043b8c97-e1d9-463a-9d5f- : On Feb 15, 12:31*am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. *Only true as long as you don't bust airspace or aircraft operating limitations... Well, neither one has much to do with a vertical speed limit. A dive which goes over Vne? Well, yes, flight testing for instance. VNE is 10% below a tested dive speed. Alos, as I posted before, some airplanes had an emergency dive speed. Vd. I'd have to look it up to see, though. In any case, it's not a legal limit, it;'s a design limitation. Nope. It's legal from Far 91.7: (a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry. Cheers |
Descent below MDA -- what would you do? | Roy Smith | Instrument Flight Rules | 50 | August 29th 05 12:39 AM |
ANR squeal on descent | Juan Jimenez | General Aviation | 13 | August 19th 05 10:39 PM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
