Minimum rates of climb/descent for VFR
Old February 15th 08, 03:20 PM posted to rec.aviation.student,rec.aviation.piloting
Steven P. McNicoll
Default Minimum rates of climb/descent for VFR
"WingFlaps" wrote in message
When NORDO you cannot ascend or descend into
controlled space except as part of a flight plan.
Where?
Old February 15th 08, 08:26 PM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
On Feb 16, 4:20 am, "Steven P. McNicoll"
If the aircraft radio fails in flight under VFR, the pilot in command
may operate that aircraft and land if--
(i) Weather conditions are at or above basic VFR weather minimums;
(ii) Visual contact with the tower is maintained; and
(iii) A clearance to land is received.
Old February 15th 08, 08:57 PM posted to rec.aviation.student,rec.aviation.piloting
Steven P. McNicoll
Descent below MDA -- what would you do? Roy Smith Instrument Flight Rules 50 August 29th 05 12:39 AM
ANR squeal on descent Juan Jimenez General Aviation 13 August 19th 05 10:39 PM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
