On Feb 16, 4:20 am, "Steven P. McNicoll"
wrote: "WingFlaps" wrote in message ... When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. If the aircraft radio fails in flight under VFR, the pilot in command may operate that aircraft and land if-- (i) Weather conditions are at or above basic VFR weather minimums; (ii) Visual contact with the tower is maintained; and (iii) A clearance to land is received. |
![]() "WingFlaps" wrote in message ... On Feb 16, 4:20 am, "Steven P. McNicoll" wrote: "WingFlaps" wrote in message ... When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. If the aircraft radio fails in flight under VFR, the pilot in command may operate that aircraft and land if-- (i) Weather conditions are at or above basic VFR weather minimums; (ii) Visual contact with the tower is maintained; and (iii) A clearance to land is received. ? |
Descent below MDA -- what would you do? | Roy Smith | Instrument Flight Rules | 50 | August 29th 05 12:39 AM |
ANR squeal on descent | Juan Jimenez | General Aviation | 13 | August 19th 05 10:39 PM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
