Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 16th 08, 08:02 PM posted to rec.aviation.ifr
Sam Spade
Default Garmin 430 rquestion- does the approach always have to be activatedvia "activate approach"?
Thomas Borchert wrote:
Sam,
VLOC is only for ILS and LOC, not RNAV
I know. However, procedure activation is treated as standard in the
manual, contrary to what you alluded to. There is no mention of
"automatic activation" I could find. Could you kindly point me to it?
No, there is no approach activation for ILS or LOC. Approach
activation, as defined for *RNAV* occurs 2 miles from the FAF. When you
select a LOC or ILS, you instead receive an advisory message cautioning
you that RNAV is for monitoring only.
Old February 16th 08, 09:15 PM posted to rec.aviation.ifr
Thomas Borchert
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Sam,
When you
Yes, but you can (and should, per the manual) activate them. So the
question remains, what exactly does that do? In my experience, it starts
both sequencing of the waypoints in the procedure and the change in CDI
sensitivity. And from my experience, same goes for an RNAV approach. The
430 just continues to fly the original flightplan if you don't make it fly
the approach - by activating it.
Thomas Borchert (EDDH)
Old February 16th 08, 10:17 PM posted to rec.aviation.ifr
Sam Spade
Sam,
When you
I agree that the manual says to activate a previously loaded approach.
But, it is overkill and unnecessary.
En route to terminal sensitivity occurs when passing within 30 miles of
the airport reference approach, whether or not an approach is loaded.,
*provided* the destination airport is the final waypoing in the flight plan.
Once flying an approach it will activate (approach sensitivity and
approach RAIM) when reasonably on course and passing inbound 2 miles
prior to the FAF.
You can hit the "activate approach" option all day long once on an
approach flight plan and inside the IAF, and nothing will happen until
you reach 2 miles from the FAF. And, the same will happen at 2 miles
from the FAF without ever pressing the "activate approach" option.
Try it in the trainer on any RNAV (GPS) IAP (or overlay IAP).
Old February 16th 08, 10:52 PM posted to rec.aviation.ifr
Terence Wilson
On Sat, 16 Feb 2008 14:17:02 -0800, Sam Spade
prior to the FAF.
Thanks Sam. Your response agrees with my simulator observations and
clears up my confusion.
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 03:45 AM
