![]() "Sam Spade" wrote in message ... Stan Prevost wrote: "Sam Spade" wrote in message ... John Collins wrote: When an approach is loaded, it is appended to the flight plan after the destination airport. As stated earlier, the waypoints in the original flight plan will sequence normally until the destination airport is reached, at which time the 430 will navigate direct to the IAF waypoint and automatically "activate" the approach sequence. To cut to the chase, those of us familiar with using FMSes know to clear the destination airport from the flight plan once the approach is loaded. In a full-press FMS, this is known as a route-discontinuity. And, clearing that discontinuity in a full-press FMS or a Garmin panel mount will get it all to work as a flight plan with continuity. On a GNS430, activating the loaded approach is simpler. PROC, ENTER. I took another look at it and disagree. Once the IAP is selected removing the airport can be done prior to a critical phase of flight, then everything sequences without pilot intervention. FPL, push small knob to get cursor, scroll down to airport, CLR, ENTER to confirm, FPL to get back to NAV page. vs PROC, ENTER. And if you have to change approaches, which sometimes happens, you can't select a new one without a destination airport. |
Stan Prevost wrote:
FPL, push small knob to get cursor, scroll down to airport, CLR, ENTER to confirm, FPL to get back to NAV page. vs PROC, ENTER. True enough. But, the bit of extra stuff earlier on is none the less easier and I don't have to worry about making sure I am where I am supposed to be if I "activate." And if you have to change approaches, which sometimes happens, you can't select a new one without a destination airport. It is rare to fly the full approach in a TRACON environment. But, if it is a single approach in each direction, you will usually still know early on. If it is a major airport then all bets are off, so I would wait until the vectors begin, then do it your way, but with VTF. However, if the airport has runway specific STARs, then there is another level of complexity, which can easily overwhelm single-pilot operations. |
![]() "Sam Spade" wrote in message ... Stan Prevost wrote: FPL, push small knob to get cursor, scroll down to airport, CLR, ENTER to confirm, FPL to get back to NAV page. vs PROC, ENTER. True enough. But, the bit of extra stuff earlier on is none the less easier and I don't have to worry about making sure I am where I am supposed to be if I "activate." And if you have to change approaches, which sometimes happens, you can't select a new one without a destination airport. John Collins informed me, and I confirmed on the sim, that if you delete the destination airport waypoint from the flight plan, and then need to select a different approach, the 430 will assume the former destination airport and will allow you to select a new procedure at that airport. It is rare to fly the full approach in a TRACON environment. But, if it is a single approach in each direction, you will usually still know early on. I don't find that it is rare to fly an RNAV approach from an IAF at a satellite airport served by a TRACON (yes at the primary airport). VOR approaches or others with PTs, yes, but not Basic T and TAA GPS approaches. But it is not too uncommon for an airport or runway to be turned around after you have been told what approach to expect. |
![]() "Sam Spade" wrote in message ... Stan Prevost wrote: FPL, push small knob to get cursor, scroll down to airport, CLR, ENTER to confirm, FPL to get back to NAV page. vs PROC, ENTER. True enough. But, the bit of extra stuff earlier on is none the less easier and I don't have to worry about making sure I am where I am supposed to be if I "activate." (and from another post) I took another look at it and disagree. Once the IAP is selected removing the airport can be done prior to a critical phase of flight, then everything sequences without pilot intervention Sam, I have reread your posts trying to make sure I understand your points. First of all, I didn't know the Garmins would self-activate, so that is something new I have learned from this thread. More on that later. I understand that you prefer to perform a more complex task rather than a two-button-task if you can move the task to a less busy period of the flight. But the "without pilot intervention" part only happens if you were already direct to the IAF at the time you deleted the airport waypoint, or deleted the airport waypoint to make the navigator sequence to the IAF when instructed to proceed direct to the IAF. Either way, it is the same result as the simpler activation procedure performed at the same point in time. If that is not true, then I am missing something in the scenario. Perhaps a simple example would help. As far as I can determine, the self-activation feature is not mentioned in the Garmin manuals. I believe another poster said the same. Personally, I am a bit uneasy about using undocumented "features" of software in critical situations. For one thing, we don't really know what is happening and if it has even been tested. Does it do the required RAIM predictions prior to the FAF? How would you know, unless it fails? Does this "feature" work under all conditions? Another thing, you don't know if the "feature" will still exist, or work the same way, if the software is updated. I wonder what the response would be if one called Garmin and asked if they approve using the navigator this way? Or the FAA? Stan |
![]() On 2/17/2008 4:54 PM, Stan Prevost wrote the following: snip I wonder what the response would be if one called Garmin and asked if they approve using the navigator this way? Try it! I have had extremely good luck with Garmin tech support transferring me to very knowledgeable people when I had something besides the usual RTFM questions. My guess is that the manuals are the problem and that the behavior is in the design spec. |
![]() "Mitty" wrote in message ... On 2/17/2008 4:54 PM, Stan Prevost wrote the following: snip I wonder what the response would be if one called Garmin and asked if they approve using the navigator this way? Try it! I have had extremely good luck with Garmin tech support transferring me to very knowledgeable people when I had something besides the usual RTFM questions. My guess is that the manuals are the problem and that the behavior is in the design spec. I would call them if I understood why I might have anything to gain from doing so. I don't yet understand how using the undocumented self-activation "feature" helps anything. Stan |
Stan Prevost wrote:
"Mitty" wrote in message ... On 2/17/2008 4:54 PM, Stan Prevost wrote the following: snip I wonder what the response would be if one called Garmin and asked if they approve using the navigator this way? Try it! I have had extremely good luck with Garmin tech support transferring me to very knowledgeable people when I had something besides the usual RTFM questions. My guess is that the manuals are the problem and that the behavior is in the design spec. I would call them if I understood why I might have anything to gain from doing so. I don't yet understand how using the undocumented self-activation "feature" helps anything. It helps me in avoiding having to activate the approach at a possible inopportune time. |
Stan Prevost wrote:
"Mitty" wrote in message ... On 2/17/2008 4:54 PM, Stan Prevost wrote the following: snip I wonder what the response would be if one called Garmin and asked if they approve using the navigator this way? Try it! I have had extremely good luck with Garmin tech support transferring me to very knowledgeable people when I had something besides the usual RTFM questions. My guess is that the manuals are the problem and that the behavior is in the design spec. I would call them if I understood why I might have anything to gain from doing so. I don't yet understand how using the undocumented self-activation "feature" helps anything. Stan Here is the official answer from my Garmin associate. He is about at the top of the engineering food chain the "Documented or not, I say what you are doing is fine. We specifically designed the approach selection to do what you describe because a pilot might learn on an ATIS frequency that he should expect a particular approach/transition long before he's actually cleared for it. So, the pilot can get ahead of the game by selecting the approach/transition and placing it into the flight plan while still navigating to the airport on his existing clearance. Then, once cleared for the approach/transition, he can remove the airport from the flight plan as you indicate, activate a direct-to the initial approach fix, or whatever he is cleared to do to get established on the approach." |
![]() "Sam Spade" wrote in message ... Here is the official answer from my Garmin associate. He is about at the top of the engineering food chain the "Documented or not, I say what you are doing is fine. We specifically designed the approach selection to do what you describe because a pilot might learn on an ATIS frequency that he should expect a particular approach/transition long before he's actually cleared for it. So, the pilot can get ahead of the game by selecting the approach/transition and placing it into the flight plan while still navigating to the airport on his existing clearance. Then, once cleared for the approach/transition, he can remove the airport from the flight plan as you indicate, activate a direct-to the initial approach fix, or whatever he is cleared to do to get established on the approach." Thanks, Sam! |
On Mon, 18 Feb 2008 07:46:16 -0800, Sam Spade
wrote: Here is the official answer from my Garmin associate. He is about at the top of the engineering food chain the "Documented or not, I say what you are doing is fine. We specifically designed the approach selection to do what you describe because a pilot might learn on an ATIS frequency that he should expect a particular approach/transition long before he's actually cleared for it. So, the pilot can get ahead of the game by selecting the approach/transition and placing it into the flight plan while still navigating to the airport on his existing clearance. Then, once cleared for the approach/transition, he can remove the airport from the flight plan as you indicate, activate a direct-to the initial approach fix, or whatever he is cleared to do to get established on the approach." Thanks for looking into that Sam. |
Video clip of an "interesting" final approach & landing | Elmo von Thud | Aviation Photos | 3 | October 7th 07 12:54 AM |
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 29th 07 06:36 AM |
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 29th 07 06:36 AM |
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? | three-eight-hotel | Owning | 7 | June 1st 06 03:28 PM |
"End of an era: USN's Tomcats make their final approach before decommissioning" | Mike | Naval Aviation | 15 | April 5th 06 03:45 AM |
