Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 18th 08, 05:46 PM posted to rec.aviation.ifr
Terence Wilson
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
On Mon, 18 Feb 2008 07:46:16 -0800, Sam Spade
Here is the official answer from my Garmin associate. He is about at
the top of the engineering food chain the
"Documented or not, I say what you are doing is fine.
We specifically designed the approach selection to do what you describe
because a pilot might learn on an ATIS frequency that he should expect a
particular approach/transition long before he's actually cleared for it.
So, the pilot can get ahead of the game by selecting the
approach/transition and placing it into the flight plan while still
navigating to the airport on his existing clearance. Then, once cleared
for the approach/transition, he can remove the airport from the flight
plan as you indicate, activate a direct-to the initial approach fix, or
whatever he is cleared to do to get established on the approach."
Thanks for looking into that Sam.
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 03:45 AM
