On Feb 19, 3:36*am, Gig 601XL Builder
wrote: WingFlaps wrote: On Feb 18, 6:31 am, Phil J wrote: Besides the _very_ light weight and very slippery design, the airplane uses a variable-pitch prop and double-slotted flaps to achieve those numbers. *That is one sexy little airplane. Yes, it makes a mockery of the US sport plane limitations. Not a mockery it just doesn't qualify under the LSA rules. Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Cheers |
![]() "WingFlaps" wrote Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Response: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. That was the intent, when they made the rule. -- Jim in NC |
"Morgans" wrote in
: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. That was the intent, when they made the rule. Well, I agree wth the reason, but not neccesarily that it's not a good reason. Remember, these guys get to pick up the mess after accidents and they know full well why they happen. A relatively inexperienced pilot in a clean, relatively high performance airplane is not a good thing. The airplane isavailable and training and certification are available to fly it, so I don't see a problem Lines have to be drawn somewhere! Bertie |
On Feb 19, 10:33*am, "Morgans" wrote:
"WingFlaps" wrote Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Response: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. *That was the intent, when they made the rule. -- I'm sure you are right, but I'd like to suggest the energy that kills in light aircraft mostly comes from gravity. In other words even 70k microlights kill if drilled in. In NZ, the new sport plane cat. will not be limted in complexity, just power and MAUW (I think). You have to be type certified so it's not like you can just jump into any old sport plane so a higher speed sport plane is not really going to be an automatic killer is it? Does the US sport plane pilot not require type certification? Cheers |
On 2008-02-19, WingFlaps wrote:
Does the US sport plane pilot not require type certification? In the US, no aircraft with a max takeoff weight under 12,500 pounds requires a type rating for any pilot unless it has a turbojet (or maybe a turbofan) engine. Insurance companies usually insist on owner pilots having between 5 and 10 hours in type before they'll insure the aircraft for solo operation, but that's not a regulatory requirement. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net http://www.hercules-390.org (Yes, that's me!) Buy Hercules stuff at http://www.cafepress.com/hercules-390 |
WingFlaps wrote:
On Feb 19, 3:36 am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 18, 6:31 am, Phil J wrote: Besides the _very_ light weight and very slippery design, the airplane uses a variable-pitch prop and double-slotted flaps to achieve those numbers. That is one sexy little airplane. Yes, it makes a mockery of the US sport plane limitations. Not a mockery it just doesn't qualify under the LSA rules. Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Cheers I didn't even look at the cruise speed. Assuming the variable-pitch prop is variable in flight that is what disqualifies it. |
![]() Not a mockery it just doesn't qualify under the LSA rules. Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? There's no limit on power; merely a limit on maximum cruise speed. The FAA views LSA as simple, low performance aircraft intended for recreation. "The FAA believes that a maximum speed limit is appropriate for aircraft designed for operation by persons with the minimum training and experience of a sport pilot." I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Name one "established" ready-to-fly aircraft, built in the USA, that met the current LSA standards prior to their implementation. Or are you claiming that Cessna lobbied to protect the resale value of the Cessna 120? Ron Wanttaja |
On Feb 20, 3:13*am, Gig 601XL Builder
wrote: I didn't even look at the cruise speed. Assuming the variable-pitch prop is variable in flight that is what disqualifies it. Maybe you can revisit this restriction in the interests of reducing carbon emissions? :-) Cheers |
WingFlaps wrote:
On Feb 20, 3:13 am, Gig 601XL Builder wrote: I didn't even look at the cruise speed. Assuming the variable-pitch prop is variable in flight that is what disqualifies it. Maybe you can revisit this restriction in the interests of reducing carbon emissions? :-) Cheers Won't happen in LSA. The entire point is light aircraft that fly and more importantly land with minimum passengers and the simplest possible system to fly. |
WingFlaps wrote: On Feb 20, 3:13 am, Gig 601XL Builder wrote: I didn't even look at the cruise speed. Assuming the variable-pitch prop is variable in flight that is what disqualifies it. Maybe you can revisit this restriction in the interests of reducing carbon emissions? :-) Cheers Won't happen in LSA. The entire point is light aircraft that fly and more importantly land with minimum passengers and the simplest possible system to fly. Insert the word "slow" between land and with. |
Wanted: RTF or builder-assist Rotax sportplane | Office 2004 Test Drive User | Home Built | 6 | August 1st 07 11:43 PM |
MONI motorglider / sportplane for sale | Bill Berle | Home Built | 10 | August 2nd 03 12:05 AM |
MONI motorglider / sportplane for sale | Bill Berle | Aviation Marketplace | 7 | August 2nd 03 12:05 AM |
MONI motorglider / sportplane for sale | Bill Berle | Soaring | 7 | August 2nd 03 12:05 AM |
Monnett MONI motorglider/sportplane for sale | Bill Berle | Home Built | 0 | July 26th 03 10:59 PM |
