![]() "WingFlaps" wrote Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Response: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. That was the intent, when they made the rule. -- Jim in NC |
"Morgans" wrote in
: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. That was the intent, when they made the rule. Well, I agree wth the reason, but not neccesarily that it's not a good reason. Remember, these guys get to pick up the mess after accidents and they know full well why they happen. A relatively inexperienced pilot in a clean, relatively high performance airplane is not a good thing. The airplane isavailable and training and certification are available to fly it, so I don't see a problem Lines have to be drawn somewhere! Bertie |
On Feb 19, 10:33*am, "Morgans" wrote:
"WingFlaps" wrote Then may I suggest those rules are too restrictive? Why have an upper speed limit when you are already limited on power? The power, Vso and MAUW alone should be enough. IMHO if better design can give both the desired low stall speed and high speed perf. it should be encouraged, not prevented by restrictive legislation. I can't help wonder if one purpose of that legislation is to protect established, but inferior, designs. Response: I agree that the speed limit is overly restrictive, but it was put there for a purpose. It puts a limit on the amount of kinetic energy available. *That was the intent, when they made the rule. -- I'm sure you are right, but I'd like to suggest the energy that kills in light aircraft mostly comes from gravity. In other words even 70k microlights kill if drilled in. In NZ, the new sport plane cat. will not be limted in complexity, just power and MAUW (I think). You have to be type certified so it's not like you can just jump into any old sport plane so a higher speed sport plane is not really going to be an automatic killer is it? Does the US sport plane pilot not require type certification? Cheers |
On 2008-02-19, WingFlaps wrote:
Does the US sport plane pilot not require type certification? In the US, no aircraft with a max takeoff weight under 12,500 pounds requires a type rating for any pilot unless it has a turbojet (or maybe a turbofan) engine. Insurance companies usually insist on owner pilots having between 5 and 10 hours in type before they'll insure the aircraft for solo operation, but that's not a regulatory requirement. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net http://www.hercules-390.org (Yes, that's me!) Buy Hercules stuff at http://www.cafepress.com/hercules-390 |
Wanted: RTF or builder-assist Rotax sportplane | Office 2004 Test Drive User | Home Built | 6 | August 1st 07 11:43 PM |
MONI motorglider / sportplane for sale | Bill Berle | Home Built | 10 | August 2nd 03 12:05 AM |
MONI motorglider / sportplane for sale | Bill Berle | Aviation Marketplace | 7 | August 2nd 03 12:05 AM |
MONI motorglider / sportplane for sale | Bill Berle | Soaring | 7 | August 2nd 03 12:05 AM |
Monnett MONI motorglider/sportplane for sale | Bill Berle | Home Built | 0 | July 26th 03 10:59 PM |
