On Feb 18, 12:08 pm, Sliker wrote:
I'm wiring the electrical system in my Glasair 3, and would like to know how most builders wire the alternator. It seems every diagram I get from Bob Nuckolls shows the alternator supply wire (B) connecting to the input side of the starter contactor. But the wiring diagrams from B&C show the B wire going directly to the supply or main bus through a circuit breaker of appropriate amps. The main difference I see is with Nuckolls method, the alternator has to send it's current through the battery contactor. Where as the B&C diagram bypasses it and goes directly to the main bus. Which is better? Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com The input side of the starter contactor is connected to the output side of the master contactor, and a heavy line goes from that same point to feed the bus through the ammeter. Connecting the alternator to that terminal will run all its current through the ammeter, which you don't want. The ammeter would show a discharge even though the battery is charging. Run the line to the bus, through a breaker. The ammeter will then read properly, and you will have a protected circuit. Dan |
Nippondenso Alternator Wiring | CW Crane | Home Built | 1 | January 4th 07 02:05 AM |
Alternator field cycling & alternator damage | Nathan Young | Owning | 7 | November 14th 04 09:02 PM |
q alternator 152 | Euromotors | Piloting | 2 | July 16th 04 09:34 AM |
Turbo Alternator | Wyatt Emmerich | Instrument Flight Rules | 5 | January 19th 04 02:35 PM |
Skylane Alternator | MLenoch | Piloting | 1 | December 8th 03 02:37 PM |
