Alternator wiring
Old February 19th 08, 02:25 AM posted to rec.aviation.homebuilt
Doug Palmer
Default Alternator wiring
I'm not sure I am exactly following your descriptions. However one
consideration that may have Aeroelectric Bob running the B lead
through the starter contactor, is the battery can be used as something
of a filter for any alternater noise if the current goes to the
battery then the buss, as opposed to going directly to the buss from
the alternator.
Old February 19th 08, 04:15 AM posted to rec.aviation.homebuilt
Sliker
On Mon, 18 Feb 2008 18:25:48 -0800 (PST), Doug Palmer
the alternator.
That's what he does it for, to reduce the noise from the B lead, from
what I gathered reading his book.
Rich
Old February 19th 08, 05:32 PM posted to rec.aviation.homebuilt
Rich
The output side of the master contactor, and input side of
the starter contactor, are wired together and the bus is also
connected to that same point, so it will make no difference at all in
terms of noise filtering. The only difference will be a wrong-reading
ammeter, since the ammeter is installed between the master contactor
and bus, and electron flow during discharge is from the bus, through
the ammeter, and via the contactor to the battery. Connecting the
alternator to this point will have electon flow from the bus, through
the ammeter, to the alternator via that same path, making it show a
discharge at all times when the alternator is running. I don't think
you want that. If the alternator is connected to the bus (through a
breaker), the electron flow runs from the battery (backwards, so it's
charging) to the contactor and, through the ammeter to the bus and
from there to the alternator. The ammeter properly shows a charge,
since the flow is reversed, now. Isn't that what you really want?
Scroll about halfway down this page to the diagram without the
the overvoltage sensor:
http://ronkilber.tripod.com/alternat/alternat.htm
See how the alternator is connected. And see what would
happen if it was connected instead to the contactor.
Dan
Old February 19th 08, 05:54 PM posted to rec.aviation.homebuilt
Sliker
On Tue, 19 Feb 2008 09:32:59 -0800 (PST),
Rich
Dan
That's exactly the way I want to hook it up. Although, I do remember
in reading Bob's book that with that setup he suggests hooking up the
amp meter between the batteries ground post and the ground bus to get
it to read right. But I'm just going to run the alternator wire
directly to the main bus through a breaker and use shielded wire. If
the shield does it's job, the noise should be grounded out. I even
noticed that some of the later wiring diagrams from B&C show the
alternator wire connecting to the starter contactor. So they are in
agreement with Bob on that one. But that's just one way to do it,
there are others. The wiring diagram I like best is the one in The
Sportplane builder and in Firewall forward, by Tony Bengilis. And
thank goodness in his book he shows how to wire my Bendix shower of
sparks mags. That's the only place I've found that wiring diagram.
Although, after looking at it, it's pretty simple. I had thought that
the shower of sparks mags were really modern, until I read a similar
system was installed in the Model A Ford. :-)
Rich
Old February 19th 08, 07:14 PM posted to rec.aviation.homebuilt
it to read right.
If you put the ammeter between the battery's ground post and
ground, you'd have all the starter current running through it. It
would smoke pretty good. Starters draw hundreds of amps. Grounding the
starter separately would be pretty difficult, since it's grounded to
the engine through its mount, and the engine is grounded to the
airplane as a return path for both the starter and alternator, which
is also firmly grounded to the engine through its mount. The
alternator, though, should have a separate ground wire to keep noise
to a minimum.
Dan
Old February 19th 08, 07:38 PM posted to rec.aviation.homebuilt
Sliker
On Tue, 19 Feb 2008 11:14:03 -0800 (PST),
it to read right.
to a minimum.
Dan
Sounds like another reason not to use that alternator wiring method. I
also remember reading about him mentioning using a high amperage rated
shunt for the amp meter when used in that location. The issues seem to
snowball. I have one question, if the B lead were hooked up to the
starter contactor, would reversing the wires on the amp meter make it
read correctly?
Old February 19th 08, 08:50 PM posted to rec.aviation.homebuilt
read correctly?
Nope. Now it would read "charge" all the time, even during discharge.
The ammeter is an indication of what the battery is doing.
It needs to be wired as shown so that there are two directions of
electron flow so you know whether the alternator is managing to keep
up or not. If the alternator's output isn't wired to the bus itself
rather than the contactor, you'll have no idea if it's working
properly. The ammeter won't be able to tell you anything worthwhile.
Dan
Old February 20th 08, 03:39 PM posted to rec.aviation.homebuilt
Doug Palmer
(snip)
to a minimum.
Dan
Actually you can wire the ammeter using the ground post if you use an
adequate shunt to handle the load, I ran mine this way as per
Aeroelectric Bob and have not had any issues,
Nippondenso Alternator Wiring CW Crane Home Built 1 January 4th 07 02:05 AM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
q alternator 152 Euromotors Piloting 2 July 16th 04 09:34 AM
Turbo Alternator Wyatt Emmerich Instrument Flight Rules 5 January 19th 04 02:35 PM
Skylane Alternator MLenoch Piloting 1 December 8th 03 02:37 PM
