On Mon, 18 Feb 2008 18:25:48 -0800 (PST), Doug Palmer
wrote: I'm not sure I am exactly following your descriptions. However one consideration that may have Aeroelectric Bob running the B lead through the starter contactor, is the battery can be used as something of a filter for any alternater noise if the current goes to the battery then the buss, as opposed to going directly to the buss from the alternator. That's what he does it for, to reduce the noise from the B lead, from what I gathered reading his book. Rich |
On Feb 18, 9:15 pm, Sliker wrote:
That's what he does it for, to reduce the noise from the B lead, from what I gathered reading his book. Rich The output side of the master contactor, and input side of the starter contactor, are wired together and the bus is also connected to that same point, so it will make no difference at all in terms of noise filtering. The only difference will be a wrong-reading ammeter, since the ammeter is installed between the master contactor and bus, and electron flow during discharge is from the bus, through the ammeter, and via the contactor to the battery. Connecting the alternator to this point will have electon flow from the bus, through the ammeter, to the alternator via that same path, making it show a discharge at all times when the alternator is running. I don't think you want that. If the alternator is connected to the bus (through a breaker), the electron flow runs from the battery (backwards, so it's charging) to the contactor and, through the ammeter to the bus and from there to the alternator. The ammeter properly shows a charge, since the flow is reversed, now. Isn't that what you really want? Scroll about halfway down this page to the diagram without the the overvoltage sensor: http://ronkilber.tripod.com/alternat/alternat.htm See how the alternator is connected. And see what would happen if it was connected instead to the contactor. Dan |
On Feb 19, 10:54 am, Sliker wrote:
That's exactly the way I want to hook it up. Although, I do remember in reading Bob's book that with that setup he suggests hooking up the amp meter between the batteries ground post and the ground bus to get it to read right. If you put the ammeter between the battery's ground post and ground, you'd have all the starter current running through it. It would smoke pretty good. Starters draw hundreds of amps. Grounding the starter separately would be pretty difficult, since it's grounded to the engine through its mount, and the engine is grounded to the airplane as a return path for both the starter and alternator, which is also firmly grounded to the engine through its mount. The alternator, though, should have a separate ground wire to keep noise to a minimum. Dan |
On Feb 19, 12:38 pm, Sliker wrote:
Sounds like another reason not to use that alternator wiring method. I also remember reading about him mentioning using a high amperage rated shunt for the amp meter when used in that location. The issues seem to snowball. I have one question, if the B lead were hooked up to the starter contactor, would reversing the wires on the amp meter make it read correctly? Nope. Now it would read "charge" all the time, even during discharge. The ammeter is an indication of what the battery is doing. It needs to be wired as shown so that there are two directions of electron flow so you know whether the alternator is managing to keep up or not. If the alternator's output isn't wired to the bus itself rather than the contactor, you'll have no idea if it's working properly. The ammeter won't be able to tell you anything worthwhile. Dan |
(snip)
If you put the ammeter between the battery's ground post and ground, you'd have all the starter current running through it. It would smoke pretty good. Starters draw hundreds of amps. Grounding the starter separately would be pretty difficult, since it's grounded to the engine through its mount, and the engine is grounded to the airplane as a return path for both the starter and alternator, which is also firmly grounded to the engine through its mount. The alternator, though, should have a separate ground wire to keep noise to a minimum. Dan Actually you can wire the ammeter using the ground post if you use an adequate shunt to handle the load, I ran mine this way as per Aeroelectric Bob and have not had any issues, |
Nippondenso Alternator Wiring | CW Crane | Home Built | 1 | January 4th 07 02:05 AM |
Alternator field cycling & alternator damage | Nathan Young | Owning | 7 | November 14th 04 09:02 PM |
q alternator 152 | Euromotors | Piloting | 2 | July 16th 04 09:34 AM |
Turbo Alternator | Wyatt Emmerich | Instrument Flight Rules | 5 | January 19th 04 02:35 PM |
Skylane Alternator | MLenoch | Piloting | 1 | December 8th 03 02:37 PM |
