New products for US Contest Pilots from Random Logic...
Old February 19th 08, 02:38 AM posted to rec.aviation.soaring
ZZ
Default New products for US Contest Pilots from Random Logic...
Another useful algorithm might be a feature that "kept you flying"
during a landout and would make you appear to be on final glide as you
trailer back to the field.
Paul
ZZ
Marc Ramsey wrote:
Thanks to the proposed changes to section 6.7 (Flight Documentation
Equipment) of the 2008 SSA Regional and National contest rules, Random
Logic will soon be releasing several exciting products for those pilots
wishing to optimize their scores!
For pilots in Category 3 (sports class regionals):
Find yourself falling 5 or 10% behind the scores of the top pilots in
your class? *Dial-a-Speed* (TM) is a tiny utility which runs on any
Windows Mobile or Pocket PC. Installed alongside WinPilot, SeeYou
Mobile, or other popular soaring navigation software, *Dial-a-Speed*
optimizes your task times by transparently intercepting and cleverly
adjusting each GPS fix before it reaches your nav software. Configured
by simply selecting the finish point and your desired level of
optimization, *Dial-a-Speed* allows you to fly your tasks faster by
reducing the distance you need to fly to obtain the desired task
distance. At the end of the day, you simply hand in the IGC file from
your navigation software, to be scored using your optimized distance and
actual task time!
For pilots in Category 2 (regionals, nationals, no US Team points):
The *Disreputable Flight Recorder* (TM) is a simple electronic flight
recorder that meets the needs of the budding regional and national
contest pilot. Incorporating *Dial-a-Speed* technology, the
*Disreputable Flight Recorder* allows you to increase your task speeds
without flying any faster!
For pilots in Category 1 (US Team points):
Intended for the more technologically advanced pilot, the *Secure Flight
Recorder Exchange* (TM) allows US contest pilots to trade their
IGC-approved "all flights" recorder in for an approved flight recorder
that has had its IGC approval level reduced. Each *Secure Flight
Recorder Exchange* unit is accompanied by the appropriate
publicly-available documentation detailing the reasons for the downgrade
of approval. Some assembly required.
DISCLAIMERS: Random Logic does not condone use of these products for
cheating at SSA sanctioned contests. Excessively high *Dial-a-Speed*
settings may cause your competitors to notice that you are turning short
of turn points in assigned speed tasks.
Old February 19th 08, 07:55 PM posted to rec.aviation.soaring
g l i d e r s t u d
What is the penalty for unsportsman like conduct?
Old February 19th 08, 07:58 PM posted to rec.aviation.soaring
Marc Ramsey
How do you prove it?
Old February 19th 08, 09:05 PM posted to rec.aviation.soaring
Orion Kingman
Its nice to see that someone is finally taking advantage of a rule
that was written to encourage more participation in the sport.
Old February 19th 08, 09:59 PM posted to rec.aviation.soaring
Marc Ramsey
We already have a rule permitting use of non-approved production flight
recorders and handheld GPS devices. As scorer, if I have questions as
to what is going on with one of these devices, I can request the pilot
provide the unit to me for examination and download using software I
obtain from a verifiable source. With the proposed rule, it will now be
possible for a pilot to supply an IGC file for which no alternative
means of verification exists. I suppose this will encourage some
additional participation, I'm just not sure it's all going to be the
kind we want...
Marc
Random data from a Cessna Pilots Ass'n. forum, etc. Dan Luke[_2_] Piloting 5 October 3rd 07 08:19 PM
Why The Hell... (random rant) EridanMan Piloting 321 April 13th 07 09:13 PM
Random thoughts 2 Bill Daniels Soaring 6 September 1st 06 05:37 AM
ALL USA CONTEST PILOTS [email protected] Soaring 6 January 11th 06 08:06 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 04:21 PM
