On Feb 19, 6:14 pm, "Robert M. Gary" wrote:
On Feb 19, 5:12 pm, wrote: Hey thanks, I will convey that info in terms of a question to the FBO and see what they say. I'm sure other pilots have noted this weirdness as well. Remember that the FBO's CFIs are probably flying this plane more often than solo renters. I would be surprised if the FBO doesn't already know. Either they are waiting on the part, waiting for the next 100 hours, or waiting for someone to crash as a result of this. ![]() -robert The way to find out: push the tail down to raise the nosewheel off the ground, and see if the rudder centers. If not, one spring is probably busted. Be carerful pushing the tail down. The front spar in the stab is a little light and cracks easily if this is done regularly. 172s are worse. Much worse. Dan |
* * *The way to find out: push the tail down to raise the nosewheel
off the ground, and see if the rudder centers. If not, one spring is probably busted. * * *Be carerful pushing the tail down. The front spar in the stab is a little light and cracks easily if this is done regularly. 172s are worse. Much worse. * * *Dan that shouldn't happen if you push down on the last two fuselage formers before the vertical tail, should it? |
On Feb 19, 6:26 pm, wrote:
The way to find out: push the tail down to raise the nosewheel off the ground, and see if the rudder centers. If not, one spring is probably busted. Be carerful pushing the tail down. The front spar in the stab is a little light and cracks easily if this is done regularly. 172s are worse. Much worse. Dan that shouldn't happen if you push down on the last two fuselage formers before the vertical tail, should it? Got to be careful that you don't wrinkle the skin on either side of the formers. None of this stuff is very stiff. Another way to get the nose off is to put the prop horizontal and lift it, putting your hands on the blades on either side of the spinner. DON'T EVER put any force on the spinner. They don't like that. Turn the prop backwards. Very carefully. Never take a silent engine for granted. Some of them waken rather easily. In a bad mood. Dan |
On Feb 19, 9:15 pm, wrote:
The way I was told to do it is to lay your upper body and arms across the fueslage to spread the force as much as possible and never just push down with your hands. Just adding my $0.02: My PP CFI was also an A&P for American Eagle. What he had me do was to find the middle-most spar (by finding the rows of rivets) and push down there right where it attaches to the empenage while also pushing down on the empenage with the other hand. - Joe |
Be careful pushing the tail down. The front spar in the stab is
a little light and cracks easily if this is done regularly. 172s are worse. Much worse. Dan So _that's_ why the flight school always flipped out when we did that... Now I fly a plane where the tail is _always_ down. Of course, that makes landing slightly more challenging... |
On Feb 19, 6:58 pm, Bob Martin wrote:
So _that's_ why the flight school always flipped out when we did that... You got it. Cessna has a service bulletin on the subject. Pushing the stab down places high forces on the front part of the stab, while in the air the loads are 40% back; the aft spar's construction reflects the greater load it carries. The front spar is really light and flexes through the big lightening hole in the center, and cracks in four places. Very expensive. A little dangerous, too. Now I fly a plane where the tail is _always_ down. Of course, that makes landing slightly more challenging... Airplanes are supposed to be built that way. Just compare the taildragger and trike versions of the Maule (or even the Helio Courier). What pilot would ever say that the trike looks right? (What *real* pilot?:-)) Dan |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
A Q on horizontal turns | Ramapriya | Piloting | 2 | January 8th 05 05:57 PM |
A Q on horizontal turns | Ramapriya | Piloting | 14 | January 7th 05 11:46 PM |
A320 doing S-turns at LAS | Gerald Sylvester | Piloting | 7 | May 7th 04 02:59 PM |
Slipping in Turns | Jim Hendrix | Soaring | 16 | November 30th 03 04:39 PM |
