#31
On Thu, 21 Feb 2008 22:27:27 GMT, "Jay Honeck"
wrote: I thought placarding as "INOP" was only legal for non-required equipment? Required equipment being what is listed in 91.205 ANDed with the aircraft equipment list? Apparently having three other fuel tanks to choose from makes a single tank's fuel gauge "non-required"... Not if the regulation says *EACH* tank guage. Does your equipment list have R, S, or O next to the guage for the tank? |
#32
On Feb 21, 7:13*pm, Peter Clark
wrote: On Thu, 21 Feb 2008 22:27:27 GMT, "Jay Honeck" wrote: Apparently having three other fuel tanks to choose from makes a single tank's fuel gauge "non-required"... Not if the regulation says *EACH* tank guage. *Does your equipment list have R, S, or O *next to the guage for the tank? As far as I know, typical small personal planes don't even have approved MELs. But even if the PA-28-325 had one, the wording of 91.213a only allows an MEL to impose ADDITIONAL requirements for airworthiness; an MEL doen't override the basic reqirements of 91.205. (When a regulation says "You can't do X unless Y", that doesn't mean that Y is the ONLY requirement you have to meet. For example, if a regulation says "You can't be PIC unless you have a current medical certificate", that doesn't mean that medical certification is the ONLY requirement for being PIC; rather, all requirements stated elsewhere are still in force as well.) |
#33
The Cessna was just as bad. In the wing root and a pain in the ass.
Jay Honeck wrote: Nice design, Mr. Piper. Beech Bonanza you take off the access port on the top of the wing to expose the top of the bladder where sender is located. Remove 6 or 8 more screws and sender comes out. No need for tank to be empty, down 5-10 gallons helpful. Sender out in 5 minutes. Agreed. Making the sending unit inaccessible without removing the tank is crazy. But it's just another goofy thing in aviation, non-specific to Piper products. I suspect every owner can tell a maintenance story about "stupid-design-induced-headaches" on their brand of airplane. Thankfully, the sending units on our tip tanks are much easier to work on, should that ever become necessary. |
#34
#35
Still is.
On Thu, 21 Feb 2008 18:21:59 -0700, Newps wrote: The Cessna was just as bad. In the wing root and a pain in the ass. Jay Honeck wrote: Nice design, Mr. Piper. Beech Bonanza you take off the access port on the top of the wing to expose the top of the bladder where sender is located. Remove 6 or 8 more screws and sender comes out. No need for tank to be empty, down 5-10 gallons helpful. Sender out in 5 minutes. Agreed. Making the sending unit inaccessible without removing the tank is crazy. But it's just another goofy thing in aviation, non-specific to Piper products. I suspect every owner can tell a maintenance story about "stupid-design-induced-headaches" on their brand of airplane. Thankfully, the sending units on our tip tanks are much easier to work on, should that ever become necessary. |
#36
No way it's legal to fly with an inop fuel gauge. No way would I ever
placard one as inop. Just fly it until you can get it fixed. I went thru this last fall when one of mine went belly up. That gauge was always working until someone important says it's not. Jay Honeck wrote: Yikes. You didn't even take the precaution of always using the other tank when landing, rather than using the one that doesn't tell you if it's about to run dry? Placarding INOP is for optional devices. Working fuel gauges are required for airworthiness. IMO having four gas tanks makes a single one of them "optional". After the gauge went TU, we notified our A&P, who agreed that we could wait until the annual inspection to fix it. We placarded it as INOP, and didn't use it on take-off or landings. How do visual inspection or your timer tell you if you've got an in- flight fuel leak? That's an important reason for the fuel-gauge requirement. That's why we didn't use that tank for take-offs or landings. In cruise flight, if the thing ran dry, we could always change tanks. It never did, of course. |
#37
#38
#39
On Feb 21, 8:29*pm, John Smith wrote:
In article , The float detached from the sender in the right main tank on the PA32-300 I flew to Florida a year ago. The gauge was therefore inop. The aircraft is equipped with a FS-450 fuel flow monitor. I used this in place of the specific fuel gauge. The FS-450 is accurately calibrated to within 0.2 gallons, much better accurate than the manufacturer's fuel gauge. Was I legal? Offhand, I don't see why not. FAR 91.205b9 only requires a working fuel gauge for each tank. It doesn't prohibit an additional, non- working gauge. |
#40
On Feb 21, 8:23*pm, Peter Clark
wrote: An equipment list is different from a MEL. *Cessna 172 S model, for example, has an equipment list which lists installed equipment from the factory with it's weight and whether it is Required (by type certificate), Standard (installed by factory) or Optional (owner request, wheel pants for example).- Ok, fair enough. But an equipment list can't override the 91.205b9 requirement, right? Nothing in 91.205 says "unless an equipment list says it's optional". |
Post-Annual Flight | Jay Honeck[_2_] | Piloting | 114 | March 2nd 08 10:55 PM |
Post Annual Report | Jack Allison | Owning | 7 | July 7th 07 04:37 AM |
Annual Xmas Post - HawkSanta.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
Annual Xmas Post - Flight Line Santa.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
Annual Xmas Post - 001index.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
