Post-Annual Flight
Old February 22nd 08, 01:38 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Post-Annual Flight
On Feb 21, 8:29*pm, John Smith wrote:
In article
The float detached from the sender in the right main tank on the
PA32-300 I flew to Florida a year ago. The gauge was therefore inop.
The aircraft is equipped with a FS-450 fuel flow monitor. I used this in
place of the specific fuel gauge. The FS-450 is accurately calibrated to
within 0.2 gallons, much better accurate than the manufacturer's fuel
gauge.
Was I legal?
Offhand, I don't see why not. FAR 91.205b9 only requires a working
fuel gauge for each tank. It doesn't prohibit an additional, non-
working gauge.
Old February 22nd 08, 02:03 AM posted to rec.aviation.piloting,rec.aviation.owning
On Feb 21, 8:49*pm, Peter Clark
On Thu, 21 Feb 2008 17:38:38 -0800 (PST),
Was I legal?
working gauge.
Since the FS-450 isn't TSO'd as a replacement for the facotry
installed and required fuel guage, and carries a "Do not
rely on fuel flow instruments to determine fuel levels in tanks. Refer
to original fuel flow instrumentation for primary information."
warning in the pilot's guide, I do not belive your answer is correct.
Well, my answer was just "Offhand, I don't see why not". Now I do see
why not. Thanks.
(The part about not prohibiting an additional, nonworking gauge is
correct, I believe, provided that a working legal gauge is also
present--which, from what you say, was not the case.)
Old February 22nd 08, 02:10 AM posted to rec.aviation.piloting,rec.aviation.owning
Peter Clark
On Thu, 21 Feb 2008 18:03:15 -0800 (PST),
Was I legal?
working gauge.
why not. Thanks.
Not neccessarily. You'd have to check the equipment list - if only 1
were required operational it would say 1, if both were required (I
don't see why in the case of redundant fuel guages in the same tank
but anyway) it would say 2. Example, the KOEL for the Piper Malibu
Mirage which has 2 alternators installed lists 1 as required
operational for IFR and 2 are required if flight into known icing is
anticipated (one will run things fine unless you need the heated
windshield, lift transducer, etc).
Old February 22nd 08, 02:27 AM posted to rec.aviation.piloting,rec.aviation.owning
On Feb 21, 9:10*pm, Peter Clark
Not neccessarily. *You'd have to check the equipment list - if only 1
but anyway) it would say 2. *Example, the KOEL for the Piper Malibu
Yup, no disagreement. I just meant that an inop gauge (in addition to
a legal, working one for the same tank) doesn't automatically violate
91.205b9.
Old February 22nd 08, 01:45 AM posted to rec.aviation.piloting,rec.aviation.owning
Ray Andraka
gauge.
Was I legal?
No. The FS-450 installation instructions, which are a part of the STC,
specifically say "a placard stating 'Do Not Rely on Fuel Flow Instrument
to Determine Fuel Levels in Tanks' must be mounted on the aircraft
instrument panel near the FS-450."
Of course, the float didn't fall off until right before someone
important noticed it fell off, so until it fell off you were legal ;-).
Does a tree that falls in a forest make a sound?
Old February 22nd 08, 04:05 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck[_2_]
gauge.
Was I legal?
I also have the JPI FS-450 digital fuel flow gauge in our plane, which is a
hundred times more accurate than the Piper fuel tank gauges. Even with
this very powerful tool in our arsenal, we STILL rely on only the timer, and
visual verification of fuel levels.
Bottom line: If you rely on a fuel gauge (instead of physically looking in
the tank) you are taking a risk. We did not feel that flying with an
inoperative gauge that is "normally" horribly inaccurate was taking any kind
of risk whatsoever.
Mary and I would not have flown the plane if we had not considered doing so
to be utterly, 100% safe. It appears that the regulation we may have
violated (and I'm still not convinced that we did) had little connection to
practical reality.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 22nd 08, 04:44 AM posted to rec.aviation.piloting,rec.aviation.owning
That's been affirmed several times in this thread. It's never been in
dispute. No one suggests using the gauges INSTEAD of inspection and
timing. What's being questioned is using inspection and timing ALONE,
with no way to detect a fuel leak.
Please correct me if I'm wrong, but a flow gauge has no way of sensing
the amount of fuel actually in the tank, does it? So it has no way of
indicating a leak, which is the whole crux of the matter.
It appears that the regulation we may have violated
Really? FAR 91.205b9 requires, "in operable condition", a "fuel gauge
indicating the quantity of fuel in each tank". Can you explain how you
think that could be consistent with a tank that lacks a working fuel
gauge?
had little connection to practical reality.
Unless you consider it practical to be warned if you're leaking fuel.
Post-Annual Flight Jay Honeck[_2_] Piloting 114 March 2nd 08 10:55 PM
Post Annual Report Jack Allison Owning 7 July 7th 07 04:37 AM
Annual Xmas Post - HawkSanta.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
Annual Xmas Post - Flight Line Santa.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
Annual Xmas Post - 001index.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
