Antenna installation question
Old February 27th 08, 02:51 PM posted to rec.aviation.soaring
Tim Mara
Default Antenna installation question
please see my page http://www.wingsandwheels.com/page14.htm
The basic math for 1/4 wave antenna is quite simple
1/4 wave = 234 divided by frequency or to arrive at a proper antenna length.
As an example for 123.5 would be 234 / 123.5 = 22.8"....this length should
however also take into effect the distance from the ground plane to the
antenna mast tip. Considering this though an antenna cut for 118.00 would be
23.88" and one for 136.00 MHz would be 20.64 so the total difference is only
just over 3" to cover the entire aviation band and 1/4 wave antennas are
fairly tolerant and will function with fair results several MHz off from the
"ideal" antenna length.
tim
I am installing a regular rod type antenna on the wooden turtledeck of
my plane where it will attach to only wood. I got the antenna from a
friend who didn't have the attaching hardware.
Do I need to do or know anything special to attach this antenna to
make sure it operates correctly? Does it need to have a metal plate
on the inside of the airframe to attach to or does it need to somehow
be connected to the metal part of the airframe for proper reception/
transmission? Can I just use local hardware store parts?
I will be running the cable to my handheld radio.
Thanks for any assistance.
Stan
(mechanical novice)
Old February 27th 08, 07:17 PM posted to rec.aviation.soaring
Malcolm Austin
One other thing to do is to use more than 4 wires (multi stranded computer
ribbon cable say) and cut them to suit the whole spectrum of frequencies you
will use. This way at least your ground plane will be more closely tuned..
Running the wire at different angles will also vary the impedance (50 ohm
required for a 1/4 wave) so again the different lengths will get you to a
much closer result..
Malcolm...
"Tim Mara" wrote in message
length. As an example for 123.5 would be 234 / 123.5 = 22.8"....this
length should however also take into effect the distance from the ground
plane to the antenna mast tip. Considering this though an antenna cut for
118.00 would be 23.88" and one for 136.00 MHz would be 20.64 so the total
difference is only just over 3" to cover the entire aviation band and 1/4
wave antennas are fairly tolerant and will function with fair results
several MHz off from the "ideal" antenna length.
tim
Stan
(mechanical novice)
Old February 27th 08, 08:32 PM posted to rec.aviation.soaring
Tim Mara
I have also used Foil Tape on wood gliders with good success.....foil tape
can be found at any local hardware (home depot and Lowe's also have
it)....in the heating departments, used as a "duct tape".....but don't use
common silver colored "Duct ""Duck"" tape....has to be metal
tim
"Malcolm Austin" wrote in message
you
Malcolm...
tim
Stan
(mechanical novice)
Old February 28th 08, 11:09 AM posted to rec.aviation.soaring
Dan[_4_]
tim
Please visit the Wings & Wheels website atwww.wingsandwheels.com
I echo Tim. I have metal foil tape on the inside of the turtledeck of
my Austria, and it works great. You take ground from the antenna and
connect to the foil tape. It lasts a long time (it was like this when
I bought in '95) and works cheaply.
You could also put the ground plane and antenna internally, which
would be less prone to damage, look better, and slightly improve
aerodynamics, assuming you have room for the antenna; wood is
transparent. Just a thought...
Dan
Old February 28th 08, 02:14 PM posted to rec.aviation.soaring
On Feb 28, 5:09*am, Dan wrote:
On Feb 27, 3:32*pm, "Tim Mara" wrote: I have also used Foil Tape on wood gliders with good success.....foil tape
tim
I echo Tim. *I have metal foil tape on the inside of the turtledeck of
my Austria, and it works great. *You take ground from the antenna and
connect to the foil tape. *It lasts a long time (it was like this when
Dan
Yes, my Woodstock antenna is completely inside the glider as is the
Cherokee Kids installation.
Antenna Installation on Longez Glennbob Home Built 11 May 21st 07 03:03 AM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
antenna installation in a glider? ken ward Soaring 5 May 19th 04 07:02 PM
Transponder Antenna Question Jay Honeck Owning 10 December 29th 03 04:40 PM
