On Mar 2, 5:54*am, Denny wrote:
Well, Murphy finally decided to move on... The Kid decided to work on Saturday - after saying he would not be there, which got the evil eye from me... We assembled, and wiped, and polished, and tightened, and loosened and retightened... *Finally after 4 hours it looked like an airplane again...The engines were test run... And by the third run we had found all the wires that had been jerked off , fuel valves that had been unhooked, etc. That was way more ground running than I normally do on a fresh engine, but you play the hand you are dealt.. Fired up, taxied straight out, rolled onto the active and put the lash to the old boy, straight up to 5500, balls to the wall... *That got the temps on the new cylinders, right up there... It was quite handy that the outside temp was 14 degrees (F)... *When straight and level pulled the props back to 2600, left the throttles to the firewall, leaned only until the engines ran smooth - then proceeded to fly great circles about the aerodrome... Rumor was that the ECI cylinders would seat the rings in a half hour, said event to be announced by a sudden drop in CHT... *At 18 minutes of boring around in the yellow arc there was a drop in CHT of 8C my CHT gauges read in *&^$%#! centigrade ... This drop occurred over roughly two minutes of the gauge barely inching down... *At 34 minutes the gauge got nervous again, and at 36 minutes there was a definite drop over roughly another two minutes... A solid 20C decrease in total... the gauge nailed the new number and stayed there for another half hour, so bored and thirsty, I decided to land... It took 15 minutes to go downhill with the engines still putting out power to avoid pulling a vacuum above the rings on the new cylinders... It burned a half quart of oil seating the rings... Theoretically, we are good to go for another year... Denny and Fat Albert the Apache... Glad to see you know exactly how to break in new cylinders. Working them hard does the deed properly. I hate to see the guys who baby their new motors thinking it will be better for seating in of all the good stuff. There are times I feel like duct taping the throttles wide open and force them to fly it. ;)) Congrats to you on breaking the earthly bounds again. Ben www.haaspowerair.com N801BH |
Well, It flies! | Doug Palmer | Home Built | 8 | June 17th 07 04:58 PM |
it flies and is huge. | Jim Macklin | Piloting | 12 | October 2nd 06 09:39 PM |
Elizabeth flies again, almost | Michelle P | Owning | 5 | October 9th 05 11:34 PM |
Eclipse flies again! | Mike Murdock | Owning | 0 | January 1st 05 12:38 AM |
C-119 flies again | Ron | Military Aviation | 9 | December 22nd 03 08:44 AM |
