#41
Correction: A T-28 does require a LOA letter. A limited licensed P-51D does
not require a LOA letter. V Lenoch LOOA |
#42
Subject: Best warbird to own
From: (MLenoch) Date: 11/8/03 5:30 AM Pacific Standard Time Message-id: Correction: A T-28 does require a LOA letter. A limited licensed P-51D does not require a LOA letter. V Lenoch LOOA How come no one chose a B-26 Martin Marauder? You guys don't know what good is. (grin) Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
#43
#44
not require a LOA letter. V Lenoch LOOA Vlado, A big engine 28 requires a letter. The small engine T-28A does not. It's a HorsePower thing. Matt Gunsch, A&P,IA,Private Pilot Riding member of the 2003 world champion drill team Arizona Precision Motorcycle Drill Team GWRRA,NRA,GOA |
#45
![]() Gregg Germain wrote: THREE guys? Wow I'm impressed. Was one in the nose? ;^) There was a modification of the P-38 that added a passenger seat in the nose. The troops gave it the nickname "droop-snoot". Since it replaced the guns, it was not a popular mod with the pilots. The military radio gear lived in a hole behind the pilot and was quite substantial. Remove that, and you can fit a rather cramped seat back there. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
#46
![]() Peter Stickney wrote: A Bf 108 would be rather neat, or one of the French Nord Bf 108 followons. When I bought my Maule, TAP had an ad for a 108 for the same price. It was a hard choice. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
#47
![]() Charles Talleyrand wrote: I've read three things. The p51 is unstable in pitch with full tanks and the resulting aft CG, and that a p51 has a high speed stall that's tougher than most other WWII fighters. And finally the p51 has a higher stall speed than other contemporary fighters. The balance problem is caused by the aft fuselage tank. Many Mustangs have had this removed. In any case, you won't need to fill it unless you're planning a 1600 mile trip. Stall speed in military configuration was about 95, which isn't out of line with other fighters of the era and is actually a bit lower than the Bf-109. I've read, however, that the plane doesn't give warning before the stall and drops the left wing dramatically when it does. Len Deighton claims that few military pilots three-pointed the Mustang because that gets you too close to the stall speed. Some years back, I got to watch 52 of these planes land at Sun'n Fun. Every landing was a wheel landing with the tail slightly low. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
#48
On Fri, 07 Nov 2003 16:50:42 GMT, Larry Dighera
wrote in Message-Id: : On Fri, 07 Nov 2003 10:39:34 -0600, Alan Minyard wrote in Message-Id: : How about an A-37 (or T-37) Tweety Bird? Two seats, reasonable handling, not too bad on fuel. Are these actually available? Do you have any idea of the going price? http://www.aircraft.com/listings/for...D=1041145&nh=0 CESSNA T-37C, N37VC, Upgraded Engine 20 SMOH, Complete Restoration, NAT Audio Panel, Skyforce Display, Full Dual Controls, 400 Knots with Air. Make Offer , $550,000 http://www.airshow.net/globeaero/ Warbirds (5) T-37 Dragonflys, Removed from foreign government's inventory, need complete restoration. $100,000 USD in container. Great PIREP: Budd Davisson, Air Progress, October, 1976 http://www.caaviation.com/links/fram...essnaT-37.html The T-37 is cheap (new copies are being sold by Cessna for around $350,000. |
#49
"G.R. Patterson III" wrote: orary fighters. The balance problem is caused by the aft fuselage tank. Many Mustangs have had this removed. In any case, you won't need to fill it unless you're planning a 1600 mile trip. Stall speed in military configuration was about 95, which isn't out of line with other fighters of the era and is actually a bit lower than the Bf-109. I've read, however, that the plane doesn't give warning before the stall and drops the left wing dramatically when it does. Len Deighton claims that few military pilots three-pointed the Mustang because that gets you too close to the stall speed. Some years back, I got to watch 52 of these planes land at Sun'n Fun. Every landing was a wheel landing with the tail slightly low. I only have 1 hour in a Mustang, but when doing stalls it gave plenty of warning with the stall occuring at about 81KIAS. We did not however do any accelerated stalls. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
#50
"killfile" wrote: The P-51 is a little more unforgiving than some other WWII fighters because of it's high speed laminar-flow wing - this gives it speed and range, at the cost of a more 'sudden' wing stall and a higher stall speed. The Spitfire is more forgiving to fly because, due to a design quirk, it's airframe actually gives a little shudder to warn you you're near a wing stall state. I've never flown a Spitfire, but if you miss the buffet on a Mustang you must be brain-dead. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Military & vintage warbird slides for sale | Wings Of Fury | Aviation Marketplace | 0 | July 10th 04 01:17 AM |
FA: 5 Airplane Model Kits - Bomber, Jet, Warbird | Disgo | Aviation Marketplace | 0 | February 22nd 04 05:00 PM |
FS: Aircraft Instruments Parts Avionics Warbird Parts | Bill Berle | Home Built | 0 | January 10th 04 02:20 AM |
New B-24 Double Feature Now Showuing at Zeno's Warbird VideoDrive-In! | Zeno | Military Aviation | 0 | September 16th 03 03:59 PM |
Warbird Runway Crash | Mark and Kim Smith | Military Aviation | 3 | September 14th 03 07:47 PM |
