On Mar 4, 3:56*pm, Stefan wrote:
Ricky schrieb: As you guessed, gas ballooning is very expensive because helium is the gas of choice, although hydrogen is becoming increasingly poular (!) with gas pilots. I dont' know about the USA, but in Europe, the only helium filled balloons you'll find are the little ones for the children. All the real ones fly on hydrogen. Helium is just way too expensive. Yeah, that is one reason why many pilots here in the U.S. are switching to hydrogen, as well. Another reason is that hydrogen is a stronger lifting gas than helium. Ricky |
On Tue, 4 Mar 2008 14:47:54 -0800 (PST), Ricky
wrote in : hydrogen is a stronger lifting gas than helium. The atmospheric displacement of hydrogen (H2 MW=2), with one fourth the molecular weight of helium (He2 MW=8), should be a considerably larger percentage of its mass. But because the hydrogen molecule is physically smaller, containing it within the balloon envelope may be an issue. My 2¢ |
Larry Dighera wrote:
On Tue, 4 Mar 2008 14:47:54 -0800 (PST), Ricky wrote in : hydrogen is a stronger lifting gas than helium. The atmospheric displacement of hydrogen (H2 MW=2), with one fourth the molecular weight of helium (He2 MW=8), should be a considerably larger percentage of its mass. Um, small correction: there is no He2 compound (well not normally). So H2 MW=2, and He MW=4. Helium is twice as dense as H2 at the same temperature and pressure. That said, both gases provide nearly the same buoyancy - H2 provides all of ~8% more buoyancy that He. That is because buoyancy depends on the differences of the densities, not their ratios. The densities at sea level a Air: ~1.29 kg/m^3 He: ~0.18 kg/m^3. H2: ~0.09 kg/m^3 Vacuum: ~0.0 kg/m^3 Turns out a vacuum provides a little under ~8% more buoyancy than H2. But because the hydrogen molecule is physically smaller, containing it within the balloon envelope may be an issue. Well, both gases eventually leak through most LTA aircraft envelope materials. (Metalclads like the ZMC-2 theoretically would fare best). But the price of helium has done nothing but rise substantially for the last few years. For some applications it has no substitute. Here's the USGS site providing stats on worldwide production, consumption, estimated reserves, and ever rising costs: http://minerals.usgs.gov/minerals/pu...modity/helium/ |
On Wed, 05 Mar 2008 05:25:22 -0000, Jim Logajan
wrote in : Larry Dighera wrote: On Tue, 4 Mar 2008 14:47:54 -0800 (PST), Ricky wrote in : hydrogen is a stronger lifting gas than helium. The atmospheric displacement of hydrogen (H2 MW=2), with one fourth the molecular weight of helium (He2 MW=8), should be a considerably larger percentage of its mass. Um, small correction: there is no He2 compound (well not normally). So H2 MW=2, and He MW=4. Helium is twice as dense as H2 at the same temperature and pressure. My 2¢ was just a guess. I knew someone would correct it. Thanks for the information. I had no clue about the relative densities. Interesting. |
In article Larry Dighera writes:
On Tue, 4 Mar 2008 14:47:54 -0800 (PST), Ricky wrote in : hydrogen is a stronger lifting gas than helium. The atmospheric displacement of hydrogen (H2 MW=2), with one fourth the molecular weight of helium (He2 MW=8), should be a considerably larger percentage of its mass. But because the hydrogen molecule is physically smaller, containing it within the balloon envelope may be an issue. But, the hydrogen molecule is 2 hydrogen atoms, at some distance. The helium molecule is 1 helium atom, so it is smaller. As I recall, helium leaks more. However, from reports, hydrogen tends to ignite rather easily. Alan |
balloon baskets | amyb | General Aviation | 2 | August 23rd 06 11:33 PM |
Hot Air Balloon Crash | Garner Miller | General Aviation | 0 | February 1st 06 06:25 PM |
Balloon-assisted jumping | JumpingMan | Home Built | 15 | March 23rd 05 10:54 PM |
Sloggi X69 hot air balloon | cotc2001 | General Aviation | 0 | May 7th 04 10:18 AM |
Wind deflectors on balloon? | Roy Smith | General Aviation | 1 | September 2nd 03 03:52 AM |
