Ron Lee wrote:
wrote: All that said, the most common argument (not necessarily one with which I'm in agreement) in favor of professional builds of experimental aircraft is that the pro shops turn out a better quality product which is less likely to injure or kill the proverbial innocent bystander. Even if we accept that at face value (which I certainly don't), it begs for the creation of a new experimental sub-category, perhaps Experimental Professional Built, with increased oversight akin to that suffered by the standard category manufacturers in pursuing and maintaining their type certificates. I also don't agree that innocents are less likely to be killed by a pro built plane. Show me the stats to prove it. The real killer is that the customer of a pro built plane may also get the repairman's certificate which means that he lied about building it. Ron Lee I have a business associate that bought a "pro-built" RV7. While he was flying home X-C the plane lost power and he safely landed in a field. He got the farmer who owned the land to tow him over beside the barn and then found and A&P to come out and see if he could fix the problem. The logs showed the plane had flown the 40 hours to get out of phase 1 testing. That A&P and another that looked at it later both felt after looking at the plane that there was no way this plane had been flown more than five or six hours. When the buyer looked further at the log book entries he realized that the that a date had been changed and that there was only, originally 3 days between the beginning and the end of the phase 1 testing. He got his money back in the deal after his lawyer made it very clear that there would either be a wire in the buyers account that day or a call would be made to the FAA. |
What is a "Pro Built"? I would take it to mean that an experimental
"kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott Gig 601XL Builder wrote: Ron Lee wrote: wrote: All that said, the most common argument (not necessarily one with which I'm in agreement) in favor of professional builds of experimental aircraft is that the pro shops turn out a better quality product which is less likely to injure or kill the proverbial innocent bystander. Even if we accept that at face value (which I certainly don't), it begs for the creation of a new experimental sub-category, perhaps Experimental Professional Built, with increased oversight akin to that suffered by the standard category manufacturers in pursuing and maintaining their type certificates. I also don't agree that innocents are less likely to be killed by a pro built plane. Show me the stats to prove it. The real killer is that the customer of a pro built plane may also get the repairman's certificate which means that he lied about building it. Ron Lee I have a business associate that bought a "pro-built" RV7. While he was flying home X-C the plane lost power and he safely landed in a field. He got the farmer who owned the land to tow him over beside the barn and then found and A&P to come out and see if he could fix the problem. The logs showed the plane had flown the 40 hours to get out of phase 1 testing. That A&P and another that looked at it later both felt after looking at the plane that there was no way this plane had been flown more than five or six hours. When the buyer looked further at the log book entries he realized that the that a date had been changed and that there was only, originally 3 days between the beginning and the end of the phase 1 testing. He got his money back in the deal after his lawyer made it very clear that there would either be a wire in the buyers account that day or a call would be made to the FAA. |
On Fri, 07 Mar 2008 17:01:42 +0000, Acepilot
wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott Pro Built is very easy to define. It's a plane licenced in the experimental/amateur built catagory that was built by someone hired by another to build it. Once someone accepts money to build someone else's plane, he becomes a professional builder. How many planes the pro builder has built in the past isn't part of the definition. What irks me is when after this process is finished, some of the persons that own the plane and didn't build it, put their name down as the builder and get the repairman certificate, and later do maintanence on this plane with questionable ability to perform it. It's crap like this that puts the homebuilt/amateur catagory in jepordy, and is now bringing on the wrath of the FAA. Now, if the name of the pro builder is put down as the builder, it's not as bad. But even this practice was not part of the original intent of the homebuilt regulations. Probably the best way for Pro builders to exist is if they built the plane for no one, then sold it. Similar to when a house contractor builds a spec house, and sells it afterwards. I would think that if the FAA had forseen what is going on now with homebuilts, they probably never would have written the rule at all or it would have been much more restrictive. Van's call to arms is falling on a lof of deaf ears. |
Acepilot wrote:
What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Ron Lee |
![]() "Ron Lee" wrote in message ... Acepilot wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Ron Lee Why should this not be allowed? This is a free country, maybe... |
On Fri, 07 Mar 2008 23:11:34 GMT, "Blueskies"
wrote: "Ron Lee" wrote in message ... Acepilot wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Why should this not be allowed? This is a free country, maybe... Certainly! And that's why the Experimental-Exhibition category exists. The Experimental Amateur-Built category is specifically for those who build aircraft for education or recreation. If someone wants to build a plane for money, let them get them certified in one of the other five Experimental categories. Heck, there are over 5,000 planes certified as Experimental Exhibition, it's not like it's new territory. Ron Wanttaja |
Ron Wanttaja wrote:
On Fri, 07 Mar 2008 23:11:34 GMT, "Blueskies" wrote: "Ron Lee" wrote in message ... Acepilot wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Why should this not be allowed? This is a free country, maybe... Certainly! And that's why the Experimental-Exhibition category exists. The Experimental Amateur-Built category is specifically for those who build aircraft for education or recreation. If someone wants to build a plane for money, let them get them certified in one of the other five Experimental categories. Heck, there are over 5,000 planes certified as Experimental Exhibition, it's not like it's new territory. Ron Wanttaja Wouldn't you love to see the RV-6 as a certified airplane! |
Blueskies wrote:
"Ron Lee" wrote in message ... Acepilot wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Ron Lee Why should this not be allowed? This is a free country, maybe... It is allowed. They jet have to get it certified. |
Acepilot wrote:
What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott Ace you might want to read the thread there Ace. A "pro-built" in the context of this thread is a a person that is building an aircraft under the guise of the homebuilt rules for profit instead for recreation and education as allowed by the law. I used to term "pro-built" instead of the more apt "law breaking, risking my ability to build an airplane, asshole." |
A Call to Arms from Richard VanGrunsven | Jim Logajan | Piloting | 181 | May 1st 08 03:14 AM |
Flew home and boy are my arms tired! | Steve Schneider | Owning | 11 | September 5th 07 12:16 AM |
ASW-19 Moment Arms | jcarlyle | Soaring | 9 | January 30th 06 10:52 PM |
[!] Russian Arms software sale | Naval Aviation | 0 | December 18th 04 05:51 PM | |
Dick VanGrunsven commutes to aviation | Fitzair4 | Home Built | 2 | August 12th 04 11:19 PM |
