#31
Larry Dighera wrote in
: On Fri, 07 Mar 2008 13:29:11 -0600, Gig 601XL Builder wrote in : Larry Dighera wrote: On Fri, 07 Mar 2008 10:36:39 -0600, Gig 601XL Builder wrote in : I have a business associate that bought a "pro-built" RV7. While he was flying home X-C the plane lost power and he safely landed in a field. He got the farmer who owned the land to tow him over beside the barn and then found and A&P to come out and see if he could fix the problem. The logs showed the plane had flown the 40 hours to get out of phase 1 testing. That A&P and another that looked at it later both felt after looking at the plane that there was no way this plane had been flown more than five or six hours. When the buyer looked further at the log book entries he realized that the that a date had been changed and that there was only, originally 3 days between the beginning and the end of the phase 1 testing. He got his money back in the deal after his lawyer made it very clear that there would either be a wire in the buyers account that day or a call would be made to the FAA. Perhaps a prudent purchaser would consider it a good idea to have an A&P look at the aircraft and logs BEFOFE the purchase. The problem that developed and caused the engine failure may or may not have been found by A&P. The log book entry would probably not have been noticed in a hanger. The point is though was that this was purchased from an A&P that was building under the Exp-HB rules buy a buyer that thought that meant he was getting a well constructed aircraft that had been properly built and tested. It's a significant expenditure, and demands due diligence of the buyer, IMO. The buyer who fails to attempt to guard against being defrauded in the situation you described shares some culpability, IMO. This is the sort of caveat emptor that keeps Consumer Reports in business. Any aircraft buyer that uses the IA who signed off the last annual inspection of the aircraft s/he is considering fails to appreciate the potential conflict of interest. I see no reason that sort of prudence shouldn't apply in a homebuilt context, especially if the buyer is aware that the seller's moral character is suspect due to the knowledge that they are both committing an act of fraud. Good grief. Bertie |
#32
#33
![]() "Bertie the Bunyip" wrote in message ... I agree. I couldn't be bothered to travel to OSH now... Bertie But OSH is pretty cool! Gotta take it for what it is, not what they say it is. |
#34
: I can see where this fraud is irksome to true craftsmen, but I can't see how it appropriate for the FAA to be involved in assuring that a prize awarded ostensibly on merit is genuinely so. Do you believe that the FAA should be involved in protecting aircraft manufacturers financial interests? Wow, you've just moved your idiocy to a whole new level there Lar. Bertie |
#35
"Blueskies" wrote in
et: "Bertie the Bunyip" wrote in message ... I agree. I couldn't be bothered to travel to OSH now... Bertie But OSH is pretty cool! Gotta take it for what it is, not what they say it is. Been there. I know what it's become... Used to be 100% terrific, now about 3-4% And I never pay attention to what "they" say, anyhoo. Bertie Bertie |
#36
cavelamb himself wrote:
Jim Logajan wrote: Jim Logajan wrote: The FAA is about to make it a whole hell of a lot harder for people to build safe amateur built aircraft. Richard VanGrunsven, founder of one of the most successful kit aircraft companies, has written up a warning and a call to arms about the issue. You can read it beginning on page 3 of this document: http://doc.vansaircraft.com/RVator/2...008-RVator.pdf Also consider using this site (to save Vans Aircraft some bandwidth load): http://www.vansairforce.net/rvator/1-2008-RVator.pdf Sounds more like they want to make it harder to_have_one_built_for_you. That appears to be what the FAA wants. But IMHO the changes the FAA is considering appear unlikely to accomplish that goal. Consider Joe Homebuilder and friends who invest in a lot of equipment and somehow set up an assembly-line-like operation and build homebuilts from "raw" material. If they fill out all the paperwork legal and proper, on what basis could the FAA claim that they had not "fabricated and assembled the majority portion of the aircraft for their own education or recreation?" These articles explain the FAA's concerns over excessive commercial abuses of the Experimental Amateur Built (E-AB) licensing category. The ARC committee was created as an FAA/EAA/ Industry process to address the FAA concerns and to recommend corrective actions. I believe Van pointed out that the FAA appears to be ignoring the concerns raised by some members of the ARC if shared credit is disallowed for the tasks on the form 8000-38 checklist. He was on the committee and clearly got negative vibes from the FAA members - and appears to be concerned enough about the impact on the entire field that he felt compelled to write his "call to arms." (If suppose if one believes that pounding 10,000 rivets is instructional and/or recreational but pounding 1000 rivets is not, fine. No accounting for taste. ;-)) |
#37
![]() "Ron Lee" wrote in message ... Acepilot wrote: What is a "Pro Built"? I would take it to mean that an experimental "kit" was built by somebody like Cessna or Piper, etc. As an amateur builder, am I a "novice" when I complete it? Will I turn pro after I finish a second one? I'd tend to say that an airplane built by Joe Blow for somebody else is still amateur built, but the owner who applies for the repairman certificate should not be able to get it if they themselves did not build 51%. Scott "pro built" in my message means that you pay someone to build it. Ron Lee Why should this not be allowed? This is a free country, maybe... |
#38
I suspect there is going to be a fall outhere.
A division between those who can read and understand the regulations, and those who can't/won't. Simple as that, Larry. |
#40
On Fri, 07 Mar 2008 00:03:24 -0600, cavelamb himself
wrote: Jim Logajan wrote: Jim Logajan wrote: The FAA is about to make it a whole hell of a lot harder for people to build safe amateur built aircraft. Richard VanGrunsven, founder of one of the most successful kit aircraft companies, has written up a warning and a call to arms about the issue. You can read it beginning on page 3 of this document: http://doc.vansaircraft.com/RVator/2...008-RVator.pdf Also consider using this site (to save Vans Aircraft some bandwidth load): http://www.vansairforce.net/rvator/1-2008-RVator.pdf Sounds more like they want to make it harder to_have_one_built_for_you. That is the reasoning behind all this, but as with many regulations it's going to take some close watching to keep them from going astray. In the past, there really wasn't a 51% rule as we think of it. They expected the builder complete 51% of the tasks. IOW, if you constructed one aileron That was as good as constructing and mounting both. Build one rib is as good as building 30. Some areas are just done much better by the manufacturer as stated in the letter. forming ribs as an example. In the past IIRC you could share the wing, aileron, elevator and stab construction with the manufacturer if they stamped out the ribs and you put everything together. The FAA apparently wants to eliminate this. How they would go about it and how it would affect what we do is really an unknown at this point. There's a big gap between the *Intent* of the rule as has been interpreted AND ACCEPTED by the FAA and the *Letter* of the rule. In my G-III the fuselage shells (right, and left, along with the forward and rear belly pans are factory molded composite sandwiches. The builder spends many hours just jigging, aligning, and bonding these sections. The horizontal stab comes with pre molded ribs and shear webs (which have to be cut to size) along with the upper and lower shells, but putting one together is a long and tedious task. OTOH the elevator, ailerons, and flaps only come as shells. You get to figure out the dimensions of the ribs. They give a bit of guidance on the lay ups but absolutely nothing on the dimensions or shaping of those ribs. The G-III is probably one of the most, if not the most labor intensive kit out there at a conservative 4000 hours for construction. Few make it in that little a time.. Even the fast build (Jump start in their dictionary) still takes thousands of hours to complete. there is a good chance the way they are wording some things that even this kit might be affected. These articles explain the FAA's concerns over excessive commercial abuses of the Experimental Amateur Built (E-AB) licensing category. The ARC committee was created as an FAA/EAA/ Industry process to address the FAA concerns and to recommend corrective actions. Unfortunately as logical as that sounds it doesn't necessarily follow that any rules changes will be as logical. Even as currently written changing from the Intent to the letter of the rule would be a drastic change. I doubt with what I'm building if the rules changes would have much effect. OTOH contrary to probably most on the group, I see little problem or even downside to changing it to a 20 or 25% rule. I happen to like building and by doing so I can also end up with a plane that has capabilities not available in production aircraft AND end up with one I couldn't afford to purchase outright. OTOH I have no problem nor do I see a problem with some one hiring the same plane built for them as long as it still has to abide by the flight restrictions of other E-AB aircraft.. I say this for two reasons that are very apparent to me. Although many of us build for the fun of it (education is rarely one of the top reasons, or even one of the reasons.) From what I've seen and we have quite a few homebuilts at 3BS (kit and scratch built), most are constructed either to save money or just because they like to build. One more reason is they couldn't purchase a plane like they want to build even if they did have the money and we have quite a few who are flying two and even three engine jets.OK only one is flying a three holer. Yes I'm learning things and some would call that education which it is, but I'll state outright, that has nothing to do with me building. I'm building because I like to do it! I'd get more enjoyment out of building another because I could do it more efficiently, faster, and cheaper. HOWEVER if I ever do get the thing finished and I'm able to fly it, my main/only reason for building at that time would be "flying an airplane I constructed myself". Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Flew home and boy are my arms tired! | Steve Schneider | Owning | 11 | September 5th 07 12:16 AM |
ASW-19 Moment Arms | jcarlyle | Soaring | 9 | January 30th 06 10:52 PM |
[!] Russian Arms software sale | Naval Aviation | 0 | December 18th 04 05:51 PM | |
Dick VanGrunsven commutes to aviation | Fitzair4 | Home Built | 2 | August 12th 04 11:19 PM |
Small arms locker questions | Red | Naval Aviation | 4 | July 30th 03 02:10 PM |
