![]() "Jay Honeck" wrote in message news:Y1oAj.13142$TT4.11271@attbi_s22... The gap varies somewhat (the two pieces that mate are quite large) from 1/3 to 1/2", but with a solid "lip" of fiberglass backing the gap. The unit is every bit as strong and sound as new, but that little gap just begs for a piece of tape to smooth the airflow... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Isn't that what high-speed (duct) tape is for? :-o |
A friend of mine experimented with duct tape on his flap gaps a few years ago. Unfortunately he chose the flight into OSH for his test flight. Imagine his horror when he couldn't deploy the flaps when trying to land on the green dot, short behind another aircraft... Duct tape isn't a great choice for that sort of thing... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mar 8, 8:40*am, "Jay Honeck" wrote:
Isn't that what high-speed (duct) tape is for? A friend of mine experimented with duct tape on his flap gaps a few years ago. *Unfortunately he chose the flight into OSH for his test flight. Imagine his horror when he couldn't deploy the flaps when trying to land on the green dot, short behind another aircraft... Duct tape isn't a great choice for that sort of thing... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993www.AlexisParkInn.com "Your Aviation Destination" Tape on a joint that will expand during its movement is not a smart thing to do. In fact that pilot should hang his head in shame for not using common sense. Without seeing the application my guess is he taped up the top of the wing/flap joint, the better way would have been to tape the lower joint, that one usually gets smaller during its travel. YMMV.. Either way, OSH is not the place to pull off a test phase of stupidity.... Tailwinds. Ben. |
On Sat, 08 Mar 2008 14:40:02 GMT, "Jay Honeck"
wrote: Isn't that what high-speed (duct) tape is for? A friend of mine experimented with duct tape on his flap gaps a few years ago. Unfortunately he chose the flight into OSH for his test flight. Imagine his horror when he couldn't deploy the flaps when trying to land on the green dot, short behind another aircraft... Duct tape isn't a great choice for that sort of thing... ;-) grey duct tape is good for 150knots provided that none of the edges protrude through the boundary layer. ...but I dont know about it's load bearing qualities over an air gap with dynamic pressure to one side though. for bridging a half inch gap the sort of polyurethane tape used for sealing plastic cloches in england is pretty good. I use some for sealing the gap between the tailplane and the fuselage on the Tailwind. sure it's a different colour to the white paint (a light green translucent colour) but it has stayed in place for 4 years. the glider guys use some sort of surgical tape that has embeded fiber reinforcing across the width of the tape. why are you so worried about "approval" for sealing a drag source? I'd be more worried to degrease the area of the glue bond than to seek approval to tape up a spat. after all this isnt structural and it is supposed to be gap free. Stealth Pilot |
news:6zxAj.13756$TT4.3960@attbi_s22... Isn't that what high-speed (duct) tape is for? A friend of mine experimented with duct tape on his flap gaps a few years ago. Unfortunately he chose the flight into OSH for his test flight. Imagine his horror when he couldn't deploy the flaps when trying to land on the green dot, short behind another aircraft... Duct tape isn't a great choice for that sort of thing... No kidding. An example of a better way: http://www.wingsandwheels.com/asw20_seal_tapes.htm -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Speaking of POP OUT FLOATS | SHIVER ME TIMBERS | Rotorcraft | 10 | June 21st 05 07:08 PM |
Speaking of dogs | [email protected] | Soaring | 5 | April 26th 05 05:18 PM |
Speaking of Las Vegas | Marty | Piloting | 1 | December 26th 04 08:26 AM |
Speaking of Gasoline | TO THE GROUP | Piloting | 11 | May 31st 04 06:57 PM |
speaking of stats | R. Hubbell | Piloting | 2 | November 26th 03 04:56 AM |
