radiocomm question
Old March 11th 08, 04:53 PM posted to rec.aviation.piloting
Robert M. Gary
Default radiocomm question
On Mar 11, 9:25*am, "Bob Gardner" wrote:
Your instructor was wrong. Ground control owns everything up to the hold
line for the runway in use.
Wrong for knowing local procedures? You really shouldn't put that out
there with the information we have here. For all you know he knows the
local procedures better than you. Again, there are airports where
tower takes this resposibility. Its not wrong to ask ground first but
they then just ask you to call the tower and ask them. I've been to
such ariports and I'm sure you have too. If this CFI was using local
procedures knowledge, it sure doesn't make him "wrong".
-Robert, CFII
Old March 11th 08, 05:03 PM posted to rec.aviation.piloting
Steven P. McNicoll
The instructor was wrong. If local procedures call for the pilot to be on
tower frequency for runway crossing instructions the ground controller would
have instructed the pilot to contact tower.
Old March 11th 08, 05:10 PM posted to rec.aviation.piloting
Robert M. Gary
On Mar 11, 10:03*am, "Steven P. McNicoll"
"Robert M. Gary" wrote in ...
The instructor was wrong. *If local procedures call for the pilot to be on
You would think but when I've had the same experience ground has also
assumed I knew to ask tower. The instructor is not wrong simply
because the controller forgot the instructions. If this CFI flys out
of this airport several times a day and knows the procedure, it does
not make him wrong simply because ATC forgot to state the procedure.
-Robert
Old March 11th 08, 06:08 PM posted to rec.aviation.piloting
TakeFlight
-Robert
I've flown out of KRVS in Tulsa, OK where they have an unusual
procedu after taxiing, you report your "run-up complete" to ground
and they sequence you for takeoff and give you a positive handoff to
tower when you're #1 for takeoff. Sometimes they tell you this when
you call up ground, sometimes they don't.
I'm not a controller, but doesn't the ground controller have to get
permission from (or at least coordinate with) the runway's
"owner" (tower) before allowing you to cross anyway?
Dan Luke wrote:
Didn't say it was, but I bet it's more relaxed than a busy Bravo like
Houston Hobby, for example.
They don't care much for home-made radio procedure at HOU.
Funny thing, I flew out of Hobby too back when they were still an
ARSA.... But RDU is busy enough that they don't generally allow any
training activity (touch & go's) there.
Thanks for the sanity check, all!
Old March 11th 08, 07:25 PM posted to rec.aviation.piloting
Steven P. McNicoll
An incorrect assumption.
The instructor is not wrong simply because the controller forgot the
instructions. If this CFI flys out of this airport several times a day
and knows the
procedure, it does not make him wrong simply because ATC forgot to state
procedure.
The procedure is to remain on ground control frequency until ready to
request
takeoff clearance. The instructor was wrong because he told the student
something contrary to that procedure.
Old March 11th 08, 07:26 PM posted to rec.aviation.piloting
Steven P. McNicoll
"TakeFlight" wrote in message
Yes.
Old March 11th 08, 07:38 PM posted to rec.aviation.piloting
John Clonts
ARSA.... *
Hey, I did too, when were you there? I trained out of Hobby in 84-85!
Cheers,
John Clonts
Temple, Texas
Old March 11th 08, 08:10 PM posted to rec.aviation.piloting
TakeFlight
Cheers,
John Clonts
Temple, Texas
89-90, American Flyers. Then I flew at Bay Area Aero Club at SPX and
the club at Ellington Field.
Old March 11th 08, 08:25 PM posted to rec.aviation.piloting
Robert M. Gary
On Mar 11, 12:25*pm, "Steven P. McNicoll"
request
takeoff clearance. *The instructor was wrong because he told the student
True the instructor was wrong. I would be wrong too, in fact next time
I'm at ABQ I'll be wrong again because I'll continue to follow the
procedure requested by ATC despite that fact that its wrong. So we
agree, he was wrong, I'm wrong, and he and I will continue to be
wrong.
-Robert
Old March 11th 08, 09:03 PM posted to rec.aviation.piloting
Bob Gardner
This information, taken from the Air Traffic Control Handbook, may be
useful:
"3-1-3. USE OF ACTIVE RUNWAYS
The local controller has primary responsibility for operations conducted on
the active runway and must control the use of those runways. Positive
coordination and control is required as follows:
NOTE-
Exceptions may be authorized only as provided in para 1-1-10, Constraints
Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility
Operation and Administration, Use of Active Runways, para 10-1-7, where
justified by extraordinary circumstances at specific locations.
REFERENCE-
FAAO 7110.65, Constraints Governing Supplements and Procedural Deviations,
Para 1-1-10.
FAAO 7210.3, Use of Active Runways, Para 10-1-7.
a. Ground control must obtain approval from local control before
authorizing an aircraft or a vehicle to cross or use any portion of an
active runway. The coordination shall include the point/intersection at the
runway where the operation will occur.
PHRASEOLOGY-
CROSS (runway) AT (point/intersection).
b. When the local controller authorizes another controller to cross an
active runway, the local controller shall verbally specify the runway to be
crossed and the point/intersection at the runway where the operation will
occur preceded by the word "cross."
PHRASEOLOGY-
c. The ground controller shall advise the local controller when the
coordinated runway operation is complete. This may be accomplished verbally
or through visual aids as specified by a facility directive.
d. USA/USAF/USN NOT APPLICABLE. Authorization for aircraft/vehicles to
taxi/proceed on or along an active runway, for purposes other than crossing,
shall be provided via direct communications on the appropriate local control
frequency. This authorization may be provided on the ground control
frequency after coordination with local control is completed for those
operations specifically described in a facility directive.
NOTE-
The USA, USAF, and USN establish local operating procedures in accordance
with, respectively, USA, USAF, and USN directives.
e. The local controller shall coordinate with the ground controller before
using a runway not previously designated as active.
REFERENCE-
FAAO 7110.65, Coordination Between Local and Ground Controllers, Para 3-1-4.
3-1-4. COORDINATION BETWEEN LOCAL AND GROUND CONTROLLERS
Local and ground controllers shall exchange information as necessary for the
safe and efficient use of airport runways and movement areas. This may be
accomplished via verbal means, flight progress strips, other written
information, or automation displays. As a minimum, provide aircraft
identification and applicable runway/intersection/taxiway information as
follows:
a. Ground control shall notify local control when a departing aircraft has
been taxied to a runway other than one previously designated as active.
REFERENCE-
FAAO 7110.65, Use of Active Runways, Para 3-1-3.
FAAO 7210.3, Selecting Active Runways, Para 10-1-6.
{New-2007-17 b. revised August 30, 2007}
b. Ground control must notify local control of any aircraft taxied to an
intersection for takeoff. This notification may be accomplished by verbal
means or by flight progress strips.
REFERENCE-
FAAO 7110.65, Wake Turbulence Separation for Intersection Departures, Para
3-9-7.
c. When the runways in use for landing/departing aircraft are not visible
from the tower or the aircraft using them are not visible on radar, advise
the local/ground controller of the aircraft's location before releasing the
aircraft to the other controller."
Bob Gardner
Had a dual flight the other day at RDU (runway diagram link at bottom
for reference). We requested runway 14 for departure, and ground told
us "taxi to runway 14 via Juliet, Charlie, hold short of 23L" (we were
departing from the general aviation ramp).
So I taxied out, eventually holding short of 23L on Charlie. The
instructor asked if I was going to switch to tower. I told him no,
that we weren't at 14 yet. He insisted that since we were holding
short of 23L that we needed to contact the tower to get across. I
disagreed.
So he called the tower and reported us as "holding short of 23L."
After a landing aircraft rolled by, tower told us to taxi to 14 and
cleared us for takeoff.
In 18 years of flying, I've never run across this before. Is this
something new, peculiar to RDU, or was he just mistaken? Whenever I've
been in this situation before, ground always was the one to tell me to
cross a runway and taxi on to my departing runway. Granted, it could
be the same controller just on a different freq....
http://204.108.4.16/d-tpp/0802/00516AD.PDF
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
OSH question Bill Chernoff Home Built 8 November 20th 04 01:07 AM
Serious question BackToNormal Military Aviation 33 November 3rd 03 06:47 PM
