Turn to Final - Keeping Ball Centered
Old March 12th 08, 05:57 PM posted to rec.aviation.piloting
Default Turn to Final - Keeping Ball Centered
I am sorry to belabor this point, but hopefully I will understand it better
if you have the patience to help me.
I understand that gravity's acceleration is indistinguishable from any other
acceleration in a frame of reference, and that it is 1g in a constant
descent or climb. I also understand that a turn is accelerating to the
center of the arc whether it is descending, level, or climbing.
Are you saying the force vector sums are equivalent when comparing level
turns at the same bank angle to constant rate descent? In other words, that
a 2g load factor occurs in a 60 degree bank regardless of whether remaining
level or a constant rate of descent and that the stall speeds are identical?
The engine power required is plainly different.
Thanks.
The center just becomes a line in that case, doesn't it? You end up
with the same centripetal force needed towards that center line in
order to turn.
Nosing over into a descent does temporarily reduce load factor, but as
soon as you're established in a constant descent, you're back at the
same 1g load. Gravity is *acceleration*, not *velocity*.
James Carlson, Solaris Networking
Old March 12th 08, 06:44 PM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
Thanks.
In the case of descending flight, gravity is supplying some of the power
required to maintain flight. With wings level, you are at 1.0 g whether
climbing, level or descending. The same rules apply to turning flight.
Remove _'s from email address to talk to me.
Old March 12th 08, 08:04 PM posted to rec.aviation.piloting
Orval, I can't thank you enough (missing energy found!). That was the
missing piece, even though it is so obvious after you point it out. I
haven't seen that part explained or referred to in all of the usual
discussions.
Thank you very much.
"Orval Fairbairn" wrote in message
Implications of.....keeping the speed up [email protected] Instrument Flight Rules 48 January 14th 07 11:41 PM
Gamepad, stopping throttle axis from being auto-centered DenisK Simulators 1 December 20th 06 09:16 AM
Keeping a builders log Lou Home Built 24 January 28th 06 10:46 PM
Thanks for ideas on drilling a centered hole! Scott Home Built 12 October 25th 04 02:52 AM
Keeping Me Out of Your Warbird? Stephen Harding Military Aviation 47 February 12th 04 04:34 PM
